Eagle 15 Hydraulic Pump Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » August 2007 » Eagle 15 Hydraulic Pump « Previous Next »
Joe (Homermandy)
Username: Homermandy
Post Number: 28
Posted From: 24.210.165.174
Posted on Friday, August 10, 2007 - 8:54 pm:
I have a question. I have the hydraulic pump design for running the radiator fan. There is an air cylinder attached to the pump which has a regulator set for 65psi. It looks like it is supposed to push on the pump and create belt tension from the pulley. It has a shutoff valve also. How do I test if this is working? If I switch the shutoff, the cylinder does not depress. I'm wondering if the tension on the belt is enough....
Joe (Homermandy)
Post Number: 29
Posted on Sunday, August 12, 2007 - 10:15 am:
I checked the air cylinder and it is working correctly.
On a side note, I disconnected the two lines at the thermocouple and connected them together. I assumed since I was bypassing the thermocouple, I would have full fan speed. It didn't make much of a difference, meaning I was not getting blown away by the fan. Should this concern me? It also looks like the fan rotation and the fins would pull air into the engine bay. Sound correct?
Joe (Homermandy)
Post Number: 30
Posted on Sunday, August 12, 2007 - 2:51 pm:
Excellent info.
http://domweb.sauer-danfoss.com/domdb/SauerLit.nsf/1526f939eb2e202286256c5b0062ff21/C1A469 F4F55E628C86256CC7006AF540/$file/520L0824_Fan%20Drive%20Control%20ME_TI_Nov-2005_Rev%201.pdf
It's actually the reverse. As coolant temp increases, valve closes increasing pressure...
