Buddy Tennison (Buddyten)
Post Number: 37 Registered: 7-2005 Posted From: 207.68.234.24
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, August 13, 2007 - 11:51 pm: | |
Can anyone give me an idea where the oil sending unit is located on an 8V71? I think it is either going bad or the wire connecting to it is shorting. No problems with oil or engine and all is fine there, but the oil pressure needle "twitches" ever so slightly, and it is bothering me. I checked the connections on the back of the gauge and they seem OK (cleaned them, etc). I thought I would check on the sending unit next and the wiring before I invest in a new gauge. Also, what should be a "good rule of thumb" oil pressure. Ours stays pretty consistently around the 50 lb mark, occassionally up around 52. What "range" is acceptable. I realize that it may change some with loads, etc. |
Larry Baird (Airhog)
Registered Member Username: Airhog
Post Number: 125 Registered: 1-2001 Posted From: 71.102.32.44
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 14, 2007 - 1:50 am: | |
JC Alacoque (Jc_alacoque)
Registered Member Username: Jc_alacoque
Post Number: 43 Registered: 7-2006 Posted From: 74.127.203.95
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 14, 2007 - 9:57 am: | |
After trying to fix my oil press. gauge many times without success,(suspecting a chaffed wire somewhere), I ran a 1/8" in. tube from where the sending unit was all the way to the dash to a mechanical gauge. Works great and is accurate. |
Post Number: 443 Registered: 11-2005 Posted From: 63.97.117.52
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 15, 2007 - 12:08 am: | |
I had the same thing on my 671. I slightly squeezed the wire clip going to the sender terminal with pliers and that was the end of it. |
