Buddy Tennison (Buddyten)
Post Number: 39 Registered: 7-2005 Posted From: 207.68.234.24
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 16, 2007 - 12:06 am: | |
I have VDO gauges in the dash on my Eagle. Some of the lights in the gauges are burned out. They are really small. Does anyone have a source or suggestion on where to get replacement bulbs? |
Gary Pasternak (Cessna5354)
Registered Member Username: Cessna5354
Post Number: 31 Registered: 2-2007 Posted From: 205.188.117.73
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 16, 2007 - 5:54 am: | |
Check Swiss Army Vehicles in Fayetteville Ar. I purchased a dozen 2 years ago. No problems and were the 24 volt needed. If you cannot locate I will send the link. Kinda on the run this AM. Take care Gary |
J.C.B. (Eagle)
Registered Member Username: Eagle
Post Number: 129 Registered: 12-2000 Posted From: 166.214.159.210
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 16, 2007 - 8:28 am: | |
Buddy you can take an old bulb to NAPA and they will order them for you. |
Post Number: 447 Registered: 11-2005 Posted From: 63.97.117.20
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 16, 2007 - 4:17 pm: | |
Try this, http://www.bulbconnection.com/ViewCategory/bcrw/catcode/SBM/pg/1/item.html |
Doug Ritter (Texrbama)
Registered Member Username: Texrbama
Post Number: 29 Registered: 3-2007 Posted From: 68.247.151.225
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 17, 2007 - 12:43 pm: | |
I repaced my lights using NAPA. Many other areas you can search using the web like VDO. Question for J.C.B., I'm wanting to add an awning on my eagle. I see you have one. who is my point of contact?. Thanks, |
J.C.B. (Eagle)
Post Number: 130 Registered: 12-2000 Posted From: 166.214.159.210
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 17, 2007 - 3:18 pm: | |
Doug I got a Zip Dee so I could walk under the arms without beating all the hair off my head. I only have two left and I want to save them. Now with all of the automatic awnings I would look at them. You can contact Zip Dee direct and they will install them at their factory out side of Chicago. Most RV dealers will install them. Mine is 23 feet long and Zip Dee is the only company that has them that long. (Message edited by eagle on August 17, 2007) |
Post Number: 26 Registered: 10-2006 Posted From: 76.223.83.13
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 17, 2007 - 9:20 pm: | |
If you have 24 volt dash bulbs and they are very dim and hard to see at night put a volt meter on the reostat and mark the position where it is 14 or 15 volts and put a stop on it there. Then switch to 12volt bulbs in the guages! |
