Oil Pressure Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » August 2007 » Oil Pressure « Previous Next »
Buddy Tennison (Buddyten)
Username: Buddyten
Post Number: 40
Posted From: 207.68.234.24
Posted on Friday, August 17, 2007 - 12:02 am:
Guys: The other day in a post, I asked several questions, the last being what should the oil pressure be running (within a reasonable range) on my 8V71. I have been having some twitch in the oil pressure gauge, but it remains kinda constant within a 48-52 lb area. In talking with my mechanic, he says anything above 35-38 is acceptable, although preferably higher. On a slow idle, it does drop down to the 10-20 lb range, and in going thru the gears will sometimes get up to about 60. I know there may be some issue on the gauge, and I am addressing that, but sure would like to know what you guys feel that a good oil pressure should be
Username: Ace
Post Number: 611
Posted From: 70.221.36.43
Posted on Friday, August 17, 2007 - 8:51 am:
Personally, I wouldn't touch it! ANY oil pressure is good oil pressure in any DD! My 8v92 only has about 15lbs at idle when warm but runs a constant 50-60 while driving! It's always going to fluctuate on the gauge!
Ace
Justin Griffith (Justin25taylor)
Username: Justin25taylor
Post Number: 32
Posted From: 74.193.73.245
Posted on Friday, August 17, 2007 - 10:27 am:
Same here
David Dulmage (Daved)
Username: Daved
Post Number: 175
Posted From: 142.46.199.30
Posted on Friday, August 17, 2007 - 11:02 am:
The numbers you have given sound good. I wouldn't worry about it.
DaveD
Doug Ritter (Texrbama)
Username: Texrbama
Post Number: 31
Posted From: 68.247.151.225
Posted on Friday, August 17, 2007 - 1:02 pm:
Buddy, I run the same motor as you. Idle cold 15 psi. Idle hot 5-10 psi. Highway speed, 40+ psi.
It has been my experience, if my guage starts to (twitch) I'm due for about a 1/2 - gal. of oil. However this does not happen that often bacause I check very often.
The short of this is, I concur with the other post on this subject.
Happy Bussing.
Username: Niles500
Post Number: 770
Posted From: 72.91.168.92
Posted on Friday, August 17, 2007 - 10:17 pm:
My 8v92 is tight and just over 100k - but no better psi than above posts - FWIW
Username: Chessie4905
Post Number: 722
Posted From: 71.58.117.21
Posted on Friday, August 17, 2007 - 10:36 pm:
You know, I don't think any of these have much oil pressure at idle because of all of the lube supply takeoffs, and oil pressure is read at end of line. I beleive many think their engine has a problem, but don't talk about the low idle pressure. Very rare for a Detroit to lose a crank due to oil pressure; usually the pistons will seize first if run low on oil.
Username: Dreamscape
Post Number: 96
Posted From: 166.129.223.35
Posted on Friday, August 17, 2007 - 10:52 pm:
The above posts have been my experience also.
andy osorio (Andymech92)
Username: Andymech92
Post Number: 4
Posted From: 68.228.209.230
Posted on Tuesday, August 28, 2007 - 4:35 am:
The oi preassure that u have its great one of the reasons while oil prs on 92,71 its that it has so many oil passages and galley and pump doesnt spin fast enough at low idle thats why its so important to keep on fast idle to keep oil prs and cooling blowers spining at a fast speed and dont forget your voltage outputs.
