I can finally post so watch out for a... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » August 2007 » I can finally post so watch out for all the PD4107 Qs « Previous Next »
Chris (Thequagmireman)
Username: Thequagmireman
Post Number: 1
Posted From: 75.49.6.63
Posted on Friday, August 17, 2007 - 12:02 pm:
Wow for so long i tired to register on here and it finally worked!!!
First Question:
What oil filter would be used on a 1967 PD-4107?
Spin on or cartrage?
2:
What type of oil is acceptable to use in the 4 speed manual Spicer tranny?
3:
...... I guess i should make seperate threads for seperate topics
Username: Rjlong
Post Number: 1278
Posted From: 67.181.189.94
Posted on Friday, August 17, 2007 - 12:17 pm:
Chris -
Welcome aboard!
Not sure of the filter numbers, they're in the bus.
But you can use the same oil in the tranny that you use in the engine (CF-2, Straight 40wt, 1% or less sulfated ash content), altho some busnuts have used single weight synthetic with good results.
What's the VIN on your 4107?
FWIW & HTH. . .
Post Number: 2
Posted on Friday, August 17, 2007 - 12:31 pm:
The bus is an hour away and the place that has the filters is the opposite direction from where I am now :-(
I can let you know my VIN this weekend
Whats FWIW and HTH ?
Username: Chessie4905
Post Number: 720
Posted From: 71.58.117.21
Posted on Friday, August 17, 2007 - 5:09 pm:
Unless an adapter has been added, it should have a cartridge-#6437275 should be the part number. Any NAPA can get it by crossing over the number, or any large auto parts store for that matter.
Post Number: 7
Posted From: 12.75.84.66
Posted on Friday, August 17, 2007 - 5:32 pm:
My VIN is 4107-671
Thanks John!
dutch (Dutch)
Username: Dutch
Post Number: 112
Posted From: 66.68.98.151
Posted on Friday, August 17, 2007 - 9:07 pm:
fwiw :For What It's Worth
hth: Hope This Helps (or is it that helps??)
