Series 60's question Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2001 » January 2001 » Series 60's question « Previous Next »
Chuck (Chuckspeed) (24.108.61.69)
Posted on Tuesday, January 23, 2001 - 4:49 pm:
I must say that it seems like the number of posts has gone down in the past month?
My question is what is the difference between a 400hp 12.7L and a 500hp 12.7L? Can they be changed?
Terrance A.Haag (Mrbus) (152.163.197.68)
Posted on Tuesday, January 23, 2001 - 5:59 pm:
Chuck,
The 60 series are the same, just different settings, contact your local DD shop, and they can set either one for the desired horsepower.
Hal (64.12.101.158)
Posted on Tuesday, January 30, 2001 - 2:05 am:
Chuck,
The engine will need a few parts to be brought up to 500hp. First, it will have to be a DDEC III. The oil cooler,cam,injectors and turbo are different. You may also run into a problem with your local dealer changing the program to 500hp without the vehicle manufactors approval. Things aren't as simple as they once were...
