Glenn Williams (Glenn)
Post Number: 76 Registered: 6-2006 Posted From: 216.163.56.78
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 09, 2007 - 9:58 am: | |
I need to fill the system to see why it is not working and I don't have a manual yet, so I need a little help on what fluid to use in a non integral system. Thanks! |
Post Number: 1292 Registered: 12-2000 Posted From: 67.181.189.94
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 09, 2007 - 5:38 pm: | |
Glenn - Dexron ATF works fine. FWIW & HTH. . .
Post Number: 77 Registered: 6-2006 Posted From: 216.163.56.78
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 09, 2007 - 6:51 pm: | |
Thanks RJ, I did some searching in the archives and saw some discrepency between 10w40 and good ol' Dexron. I'll stick with the red stuff. Glenn |
Glenn Vining (Glennvin)
Registered Member Username: Glennvin
Post Number: 25 Registered: 10-2002 Posted From: 67.140.236.217
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 09, 2007 - 9:16 pm: | |
Glenn, Our singing group has a 1984 MC-9, NJT coach. The reservoir and Da Book recommends using SAE 10 weight oil. But Dextron 111 will also do the trick. Glenn Vining Tallulah Falls, Ga. www.tlmmusic.com |
Jerome Dusenberry (Jerry32)
Registered Member Username: Jerry32
Post Number: 39 Registered: 1-2007 Posted From: 148.78.243.50
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 10, 2007 - 8:36 am: | |
I have a 102a3 and the book says use motor oil and I have Jerry` |
Post Number: 499 Registered: 7-2006 Posted From: 66.217.105.65
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 10, 2007 - 8:03 pm: | |
The 9's use motor oil. Dah Nine Book |
Post Number: 93 Registered: 3-2007 Posted From: 76.4.149.200
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 10, 2007 - 9:58 pm: | |
hey all you guys and gals: Iwent on the web site of Glennvin and if you all like BLUE-GRASS GOSPEL go have a look and listen. cool music. Gomer riverjordanmusic.com is mine LOL |
