james (Dieseldust)
Registered Member Username: Dieseldust
Post Number: 10 Registered: 3-2007 Posted From: 205.250.0.209
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 17, 2007 - 10:12 pm: | |
hello to all can anyone tell me are the eagles from belgium any better for rust problems . cheers James |
steve gaines (Kysteve)
Registered Member Username: Kysteve
Post Number: 118 Registered: 12-2006 Posted From: 74.140.165.225
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 17, 2007 - 10:26 pm: | |
James, I got a Belgium Eagle and plenty of belgium rust to go with it...lol.. If you want to see Belgium rust got way back in the archives on the site and look at the pics early this year. http://ourbusconversion.blogspot.com fwiw I am puting american steel back in it. Steve.....in Kentucky Id like to pee on the pants leg of the guy that said Belgium steel dont rust...lol... |
Art Gill (Sandcastle)
Registered Member Username: Sandcastle
Post Number: 23 Registered: 5-2004 Posted From: 208.11.184.64
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 18, 2007 - 8:11 am: | |
NJ Eagles have the best steel called Cordan. I have just a little rust around the battery box and the bottom of the front door. Art |
james (Dieseldust)
Post Number: 11 Registered: 3-2007 Posted From: 205.250.0.209
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 18, 2007 - 12:47 pm: | |
Art please could you tell some more about the NJ Eagles,i am not familar with that one i am just starting to seriously look at purchasing a bus. |
Post Number: 642 Registered: 12-2000 Posted From: 76.1.180.218
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 18, 2007 - 1:05 pm: | |
The NJ eagles were Eagles built on a contract for the New Jersey Transportation agency. NJ spec-ed all these bus to built using Cor-Ten steel. This as a steel alloy that is much more rust resistant. These Eagles were also spec-ed with the stainless steel siding similar to what MCI used instead of the standard Eagle aluminum siding. Jack |
Arthur J Griffith (Arthurseagle)
Registered Member Username: Arthurseagle
Post Number: 41 Registered: 8-2006 Posted From: 72.236.102.200
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 18, 2007 - 3:29 pm: | |
James- All of the Eagles 15's and 20's starting in 1989 were made with the Cor-Ten steel. My bus is an 89 which came from the south west and Texas area. I stripped it all the way down to the frame and found No rust in the frame tubing. The only steel on them that is not Cor-Ten is the plate metal on the front radius corners and the wheel channel surrounds and the plate around those wheel wells. If you are looking to buy an Eagle try to find a 89 or newer from the south west. (no salt on the roads) GOOD LUCK ARTHUR |
Jim Wilke (Pd41044039)
Post Number: 186 Registered: 2-2001 Posted From: 64.83.252.235
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 19, 2007 - 7:03 pm: | |
Just my luck! I bought a December 1988 Model 15! It's from North Texas and has surface rust in the rear where the grey primer failed but only one little rusty spot under the front. Does anybody have the starting serial number for the Cor-Ten steel ones? Jim-Bob |
Post Number: 191 Registered: 10-2004 Posted From: 71.251.5.17
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 19, 2007 - 7:57 pm: | |
Jim, if you only have surface rust maybe you got lucky! Or you need to look harder! Our Gm was/is a little rusty, most buses problably have their issues with rust, just different spots and degrees of crustyness.There might be id marks for the cor-ten if still visible. good luck with your eagle. Are you looking for a bigger bus than the 04? Dave |
Post Number: 42 Registered: 8-2006 Posted From: 72.236.102.192
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 20, 2007 - 2:08 pm: | |
JIM- I always loved the Eagles but I kept hearing all these night mare stories about badly rusted Eagles, which was true because I had looked at some. My wife and I were traveling in southern Texas in our sticks and staples and desided to go to the Eagle factory in Brownsville. This was in Dec. of 1996. They gave us a tour of the factory which looked like a ghost town. Only a few buses in various stages of construction. Back to the subject- We went back to the office and one of the first things that I asked them about was why do the Eagles rust so bad. They told me that they started using the Cor-Ten steel on the tubelar frames late November of 88 for the 89 production. They said they should have started using it twenty years earlier. If your bus has spent its entire life in the mid south west with no salty roads you may have very little rust. Look in the front under the windshields and marke sign from the inside. (remove some of the panels under the dash). Also check wheelwell areas, baggage door post, and pre-engine areas. Eagles are a great bus if you don't have much rust. Best of luck. ARTHUR |
