Jim Rink (Fakeguy)
Registered Member Username: Fakeguy
Post Number: 62 Registered: 1-2005 Posted From: 24.33.84.95
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 23, 2007 - 7:08 pm: | |
We and our 62 4106 just returned from a campground where new 50 am service was recently installed. I had a "dog bone" what came with the bus that allowed me to plug in to the 50 amp post and my 30 amp cord into the other end. the result was favorable but have a few questions. I have 3 10,000 Btu AC UNITS on board. Since the voltmeter on my panel was showing 120, I ran 2 at a once showing an AMP draw of 25 total including other 120 draws such as refridge, tv, lamps etc. The breakers on one ac circuit is 15 amp and the other is 20 amp. Now for my question...is this safe...plugging into 50 amp service with a bus set up for 30 amp and what else should I know and be aware of? All comments appreciated |
Post Number: 134 Registered: 5-2007 Posted From: 166.128.223.176
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 23, 2007 - 7:28 pm: | |
What size breakers are in your main electrical panel? If you have a 50amp main breaker then you need to get a 50 amp cord. If you have a 30 amp breaker you will only be able to use that amount of incoming service. I am surprised that with your three roof airs your bus would be set up with a 30 amp breaker. |
Jerry Liebler (Jerry_liebler)
Post Number: 281 Registered: 3-2005 Posted From: 67.141.38.149
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 23, 2007 - 7:38 pm: | |
Jim, It should be safe IF the bus is wired properly. That means that there is a 30 amp main breaker and other smaller breakers 'below' it. If you only have the 2 breakers you should consider re wireing, as it's possible to draw 35 amps which will overheat a minimal 30 amp cord. You probably should rewire anyway because each air conditioner should be on it's own breaker. Regards Jerry 4107 1120 |
James Stacy (Jimstacy)
Post Number: 106 Registered: 1-2001 Posted From: 75.40.238.238
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 23, 2007 - 8:10 pm: | |
When you plug into a "50 Amp" service (which allows 50 amps draw on each of two legs) and use a 30 amp adapter (30 amp on one leg) it will draw only from one leg, but will allow 50 amp flow. This means you have a 50 amp breaker on a 30 amp wire. This 50 amp breaker will allow way more current on your 30 amp adapter than the mfg intended. It is important your service cord get to a 30 amp breaker asap for the protection at least after the 30 amp breaker. The adapter will still only have 50 amp protection. Unless your coach was wired to code, you might be able to "cheat" and draw more than the capacity of your power cord. It's not unusual to see a 50 to 30 adapter in meltdown. Be really careful with your loading. As Paul and Jerry were getting to very politely, if you have 3 ac units you should have 50 amp service ability. IMHO Jim Stacy |
Jim Rink (Fakeguy)
Post Number: 63 Registered: 1-2005 Posted From: 24.33.84.95
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, September 23, 2007 - 9:08 pm: | |
Wow..thanks for all the great and quick combacks. I need to clarify a few things on my original post. 1. Paul..not sure what what my main breaker is...will check but guessing 30 amp. 2. I have a separate circuit (1 20 amp and 2 15AMP) for each ac unit which are not roof type. They are Frigid King built in: 2 below deck and 1 built into the rear cabin. Will check main next weekend and report back...meanwhile thanks again and any more comments welcomed |
Post Number: 503 Registered: 11-2005 Posted From: 63.97.117.39
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 26, 2007 - 5:23 pm: | |
Jim, Now I'm confused. On one of the boards I read that a 50a-30a adapter uses just one 25a leg of the 50a outlet?? |
Post Number: 1992 Registered: 1-2001 Posted From: 75.108.72.199
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 26, 2007 - 6:41 pm: | |
Gus, there is no 25 amp leg on a 50 amp outlet. There are two hot legs, each rated at 50 amps each. Voltage between the two hot legs is 240 volts. Voltage between either hot leg and neutral is 120 volts. Richard |
Post Number: 518 Registered: 7-2006 Posted From: 66.217.101.111
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 26, 2007 - 9:28 pm: | |
Richard - We've been to many, many campgrounds, where the "50 amp" receptacle consisted of a 30a leg and a 20a leg. The circuit breaker panel usually had one 30 and one 20 installed for that receptacle.. (several campgrounds used the older glass screw-in fuses) Yeah, it's not right... and yeah, it should be 50a per leg x2 in the "official" 220v capacity.... But.... The campgrounds only tell you they provide "50 amp service", -not- 220v service, and finding that there is only a total of 50 amps service from a provided outlet should never be a surprise to anyone. Everyone should be made aware of the lack of conformity, and the disregard of codes at campgrounds. Safety of service should never be taken for granted. "I don't think we're in Kansas anymore, Toto" |
Post Number: 138 Registered: 5-2007 Posted From: 64.40.222.139
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 26, 2007 - 11:08 pm: | |
What Richard said, that is the correct information. |
Post Number: 270 Registered: 8-2006 Posted From: 207.231.75.253
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 27, 2007 - 12:48 am: | |
Paul, John is right too. Also what MUST be looked at is Sean's post on mis-wired 50 amp campground services! If one of these joints uses the same hot leg to power the 20 and 30 amp receptacles, the neutral current can be right at 50, without tripping any breakers. Two 30 amp receptacles adapted together to run a 50 amp service will melt the neutral if they're not on opposite legs! So, check for voltage between the hot legs. 240V is correct, 0 is TROUBLE! Thanks Sean for thinking about this! George |
Post Number: 520 Registered: 7-2006 Posted From: 66.217.105.39
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 27, 2007 - 2:21 am: | |
Ditto, George! And Thanks! What should be found at campgrounds, isn't always found. It's best to take a voltmeter,or an inexpensive "Kill-A-Watt" unit, and test every power pole you intend to hook to. Test the ground bond as well. Much can be learned at the RV forums; they're not travelling in million dollar rigs, and staying at high end resorts. The small, no-frill, romantic hideaways, are where you'll find the variables.... (and, at many county and state campgrounds) (well worth it, tho!) Thanks again, George! |
Sean Welsh (Sean)
Post Number: 672 Registered: 1-2003 Posted From: 67.142.130.31
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 27, 2007 - 12:38 pm: | |
George wrote: Also what MUST be looked at is Sean's post on mis-wired 50 amp campground services! The post to which George refers is in another thread. Here's a direct link: http://www.busnut.com/bbs/messages/11/18971.html?1190606939#POST120026 -Sean http://OurOdyssey.BlogSpot.com |
