Bob Symonds (Bob_symonds)
Registered Member Username: Bob_symonds
Post Number: 28 Registered: 5-2006 Posted From: 146.235.66.52
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 03, 2007 - 4:22 pm: | |
I need 2 air wiper motors for my bus. I will rebuild if necessary. Mine are both beyond repair. thanks. |
Post Number: 191 Registered: 2-2001 Posted From: 69.77.155.72
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 04, 2007 - 9:16 am: | |
I tried several years ago to find kits or new air motors for my '59 '04. I was not successful. I suggest you find a way to convert to modern "pantograph arm" wipers like you find on most later buses. Those parts are still available. I do know that some tinkering will be needed on a 4104 as there is a vertical angle support right where the newer style motor assembly would normally go. I took my measurements of placement from a 4905 I owned. Jim-Bob |
Larry D Baker (Lbaker4106)
Registered Member Username: Lbaker4106
Post Number: 70 Registered: 5-2005 Posted From: 207.69.137.11
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 04, 2007 - 9:24 am: | |
contact www.gmbusguy.com. I know he has a 4905 with wipers he is parting out |
Douglas Wotring (Tekebird)
Post Number: 251 Registered: 10-2004 Posted From: 71.59.75.212
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 04, 2007 - 4:01 pm: | |
forget which but either Peterbuilt or Kenworth air wipers are an exact match for the 4104 |
Patrick levenson (Zubzub)
Post Number: 19 Registered: 5-2007 Posted From: 70.53.191.239
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 05, 2007 - 7:17 am: | |
Tekebird, what age would the peterbuilt or kenworth have to be to have the same air wipers? Inquiring minds need to know. |
Post Number: 253 Registered: 10-2004 Posted From: 71.59.75.212
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 05, 2007 - 4:18 pm: | |
forget. My Mechanic is the type that can track these sort of things down. best bet go into a Peterbuilt or Kenwrth shop and check the stop and start points vs what you have. I would guess that they were the last trucks that used air wipers. maybe miearly 90's |
Post Number: 193 Registered: 2-2001 Posted From: 69.77.155.72
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 05, 2007 - 5:12 pm: | |
You could probably look at the trucks & tell. A 4104 has the wiper pivot point located outboard & the wipers park almost horizontally like a car versus the later models that have the pivot centered & park vertically in the center. |
