Fuel Tank Supports for GM 4106 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » October 2007 » Fuel Tank Supports for GM 4106 « Previous Next »
Denis (Denis)
Username: Denis
Post Number: 12
Posted From: 75.187.210.173
Posted on Sunday, October 28, 2007 - 2:48 pm:
I will be removing my fuel tank to check for leakage. The supports below the plywood are in poor condition and will need replacing. Anyone have suggestions on what materials to use? Any thoughts would be appreciated!
Post Number: 108
Posted From: 76.4.149.200
Posted on Sunday, October 28, 2007 - 6:40 pm:
dennis, I have used pressure treated plywood on a lot of under=carriage work with good results. you may get and put 2 layers together to compensate for the thickness. about supports, I have used just strapping from a salvage yard and when needed just weld together if necessary. avoid bolts as they may rub a hole in the tank, and all the do is keep the tank secure.
that all folks
Gomer
