Inserts needed for compression fittin... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » November 2007 » Inserts needed for compression fittings using nylon DOT air brake tubing? « Previous Next »
Username: Chucks
Post Number: 1137
Posted From: 70.2.80.29
Posted on Saturday, November 03, 2007 - 8:47 pm:
Using compression fittings, is just the ferrule needed, or is the push-in insert needed as well? I didn't think so, but finding the answer is a little elusive.
Thanks, as always!
PS: I know. Don't overtighten.
Username: Drivingmisslazy
Post Number: 2006
Posted From: 75.108.78.224
Posted on Saturday, November 03, 2007 - 9:15 pm:
I believe the push in insert is only needed when using plastic line. Not on copper line.
Username: Chucks
Post Number: 1138
Posted on Saturday, November 03, 2007 - 9:18 pm:
Thanks Richard, I am referring to nylon line.
Post Number: 113
Posted From: 76.4.149.200
Posted on Saturday, November 03, 2007 - 9:21 pm:
hey miss lazy LOL they are using push-in and compression fittings on Everything now with good results
John Jewett (Jayjay)
Username: Jayjay
Post Number: 376
Posted From: 66.136.100.70
Posted on Saturday, November 03, 2007 - 11:51 pm:
To be safe (and legal) you must use the insert, and the line has to be imprinted as rated for airbrake service. A DOT number is involved, depending on the grade of tube. The insert allows the tubing to operate at higher pressures, since the most likely failure point is at the ferrule/insert junction. The insert keeps the ferrule from cutting the tubing if overtightened, or strained sideways. To be safe buy it at a truck supply house. Cheers...JJ
Username: Chucks
Post Number: 1139
Posted on Sunday, November 04, 2007 - 12:04 am:
Thanks, JJ. I am using the real DOT airbrake imprinted tube, but on the four fittings I've done so far without the insert it just didn't seem right. Then I discovered the inserts mentioned at one of the online parts places, but they weren't clear if they were needed for that type of tube. Something told me I'd better be sure. So I'll tear it apart and do it RIGHT!
Many thanks,
Chuck
Username: Jackconrad
Post Number: 662
Posted From: 70.152.57.103
Posted on Sunday, November 04, 2007 - 8:12 am:
I was told that the inserts that fit inside the nylon tubing is to prevent the ferule (crush ring) from crushing the nylon tubing. Jack
Username: Joe_camper
Post Number: 64
Posted From: 71.239.202.82
Posted on Sunday, November 04, 2007 - 8:43 am:
The newer fittings require none of the above. They themselves are nylon and you simply push the line in and it is done. No tools necessary.
If you have seen the new plastic supply side plumbing fittings the air counterparts were actually around first.
They are also quick release and reusable. They have a collar or ring that you compress to remove the line. Paccar has been using them on semis for some time now. I update to them whenever I have to remove a line. A huge improvement and great for tight spots when you need to double wrench the brass ones to keep the line from twisting. They also do not damage, squeeze, the end of the line thus allowing it to be used over and over and over. The fittings are completely reusable too.
This is a T pictured but they come in any configuration the old brass stuff did including all compression to pipe combinations.
Check um out!
Quick release fitting
Sammy (Sammy)
Username: Sammy
Post Number: 76
Posted From: 68.237.226.130
Posted on Sunday, November 04, 2007 - 9:54 am:
If you are using the standard style compression fitting, make sure it's for nylon hose, not copper pipe. It will have a nut,ferrule, and an insert for the line - must use all to make a proper connection. if using the newer style "pushlock" connectors or fittings you just need to make sure the end of the nylon line is cut clean and square, then just push it into the fitting until it bottoms out. Good luck with your repair.
John Lacey (Junkman42)
Username: Junkman42
Post Number: 18
Posted From: 204.49.140.158
Posted on Sunday, November 04, 2007 - 11:25 am:
The ferrule is not used with dot legal fittings. Ferrules are used with nylon hose when You use pushlock fittings which are not dot legal to use on any air system involving air brake systems. My exeperience with push lock fittings has been a little less than sterling. Just My two cents worth. John
Ed Roelle (Ed_roelle)
Username: Ed_roelle
Post Number: 46
Posted From: 69.136.130.161
Posted on Sunday, November 04, 2007 - 11:47 am:
I have had the same luck as John relative to the push lock fittings - poor.
There are some DOT fittings that integrate the ferrule. In fact, they have DOT imprinted on them. I buy them at a truck parts supply company.
Ed Roelle
Flint, MI
Post Number: 114
Posted on Sunday, November 04, 2007 - 2:41 pm:
hey ya'll check on school busses.. The one we get for transportation have the push lock fittings on them and they are dot approved.
Post Number: 65
Posted on Sunday, November 04, 2007 - 8:13 pm:
If the new fittings are not DOT legal somebody better tell Mac and Peterbilt and Kenworth and Freightliner and Volvo among others because all the new trucks coming out of the factory have them.
I have never had a problem with them.
Post Number: 663
Posted From: 98.132.83.148
Posted on Monday, November 05, 2007 - 8:08 am:
I have not seen plastic push-on fittings that were DOT approved. I have used DOT approved brass push-on fittings. I was hesitant to use these until I was assigned a new ambulance that had the brass push on fittings. These fittings will have "DOT Approved" stamped on them. I purchase mine from McMaster-Carr. Jack
Username: Chucks
Post Number: 1143
Posted From: 68.240.90.104
Posted on Monday, November 05, 2007 - 3:23 pm:
To answer the original question,
YES.
The proof was seeing the condition of the ferrules done the day before (without any inserts) when I cut them all off to insert the inserts with new ferrules.
Without the insert, the ferrule can't stay straight and becomes deformed and twisted. Mucho-hardo to make airtight.
I'm still lurnin!
And next time will look at all the fancy new stuff.
I'll be back in just a few days with brake chamber questions! ;)
Post Number: 66
Posted on Monday, November 05, 2007 - 8:38 pm:
When we turn off our bus and do not use any air accessories it will be 2 days before the aux air compressor kicks on and that is at 75lbs and after that it will kick on maybe once every 36hrs or so. Thing is I am unsatisfied with that and am trying to improve on those #s
Dot says you can loose something like up to 10 lbs in 15 mins. and you are O/K.
Sometimes the things people put trust in and are skeptical about kill me.
Even if the plastic fittings are not approved I am wondering what the difference is, safety wise, between a plastic air line or a fitting?
If you prefer use the brass push in fittings, I have seen them too. Be sure to strip out all that plastic line for copper tubing too.
Never know when the DOT will hold an inquisition.
(Message edited by Joe camper on November 06, 2007)
Brian Elfert (Belfert)
Username: Belfert
Post Number: 40
Posted From: 209.98.146.235
Posted on Monday, November 05, 2007 - 10:46 pm:
I recently replaced a tee in an air line with a coupler since I no longer have an air operated door.
The coupler the truck parts place sold me is a pushlock brass fitting. No mention was made of any inserts and the fitting doesn't leak. The fitting was not cheap in part because of the DOT stamp.
I have a number of pushlock fittings in the accessory air lines on my bus and they don't appear to have inserts. My bus will hold air for weeks or months during the spring, summmer, and fall. It will only hold air a few days during the winter so I probably have a bit of moisture somewhere.
Maybe the inserts should really be there, I don't know. My bus is Mexican made and they may have skimped on these things.
(Message edited by belfert on November 05, 2007)
Sammy (Sammy)
Username: Sammy
Post Number: 77
Posted on Tuesday, November 06, 2007 - 7:24 am:
The only pushlock fittings I use are brass and DOT approved.
Username: Chucks
Post Number: 1148
Posted From: 68.240.247.161
Posted on Tuesday, November 06, 2007 - 10:14 am:
Yeah Brian, but I was originally not asking about pushlock fittings. Maybe next time I'll hunt them down.
Hey this morning was my first 24 hours of full suspension without settling down on the blocks. I'm getting there!
Username: Belfert
Post Number: 41
Posted From: 132.148.80.215
Posted on Tuesday, November 06, 2007 - 1:52 pm:
Opps, the topic kinda drifted through all the posts.
I did use a compression type air fitting once, but it was just for the air ride seat so any slight restriction wouldn't really matter.
