Bus Bolt Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » November 2007 » Bus Bolt « Previous Next »
John Harrelson (Jharl)
Username: Jharl
Post Number: 86
Posted From: 72.73.127.231
Posted on Sunday, November 04, 2007 - 6:32 pm:
I have been noticing that some things on the bus a comming loose. I was told that i could titen them all up if I tighen the bus bolt. any clue as to where this is.
jack
(leaving self wide open)
John Lacey (Junkman42)
Username: Junkman42
Post Number: 19
Posted From: 204.49.140.154
Posted on Sunday, November 04, 2007 - 7:31 pm:
The bus bolt will be located right behind the muffler bearing. Be sure to clean the muffler bearing with a bucket of prop wash before working with the bus bolt. If the rules are not followed the framus valve will implode. John
Glenn Williams (Glenn)
Username: Glenn
Post Number: 102
Posted From: 216.163.57.212
Posted on Sunday, November 04, 2007 - 8:06 pm:
I'ts actually best to coat the framus valve with 20wt blinker fluid to prevent implosion before using the highly corrosive (and addictive to hampsters) prop wash.
Jim Rink (Fakeguy)
Username: Fakeguy
Post Number: 67
Posted From: 24.33.84.95
Posted on Sunday, November 04, 2007 - 8:16 pm:
NEVER TOUCH YOUR BUS BOLT unless you have first changed the air in ALL your tires...stale and depressurized tire air has been blamed for the majority of inverter root canal failures
Post Number: 116
Posted From: 76.4.149.200
Posted on Sunday, November 04, 2007 - 8:28 pm:
you guys are all wrong about where the bus bolt is. ALWAYS LOOK FIRST BEHIND THE WHEEL 99.9% it is then only loose bolt on the entire coach.
Post Number: 1100
Posted From: 76.68.121.96
Posted on Sunday, November 04, 2007 - 8:38 pm:
Also, in rare circumstances, the oxygen/nitrogen mix in the atmosphere of the rear third of the coach may negatively impact your efforts. Further contamination by carbons monoxide and dioxide will decrease effciency.
Best combatted by breathing deeply, enter the area and hold your breath throughout the procedure.
Bus bolts are not to be taken lightly.
Username: Gusc
Post Number: 528
Posted From: 63.97.117.30
Posted on Sunday, November 04, 2007 - 8:56 pm:
It appears to me that this bolt has caused a bunch of loose nuts.
Username: Pete_rtsdaytona
Post Number: 409
Posted From: 208.118.13.34
Posted on Sunday, November 04, 2007 - 8:59 pm:
What you REALLY needed to do is
tighten the bus NUT
(Message edited by pete RTS/Daytona on November 04, 2007)
JR Lynch (Njt5047)
Username: Njt5047
Post Number: 192
Posted From: 69.132.233.230
Posted on Sunday, November 04, 2007 - 9:30 pm:
Since I've got an MCI, and only EAGLEs have bus BOLTS...and my nuts are pretty tight. I think...?
Does that mean my only problems would be related to my muffler bearing?
BTW, how much does an MCI muffler bearing cost?
JR
Username: John_mc9
Post Number: 540
Posted From: 66.217.102.56
Posted on Sunday, November 04, 2007 - 9:44 pm:
Re:
"Since I've got an MCI, and only EAGLEs have bus BOLTS...and my nuts are pretty tight. "
I heard that Prevost owners have the tightest nuts of all!
Username: Ace
Post Number: 694
Posted From: 70.220.53.94
Posted on Sunday, November 04, 2007 - 10:41 pm:
Hmmm, I happen to own one but...
james dean boggs (Jd_boggs)
Username: Jd_boggs
Post Number: 121
Posted From: 71.146.79.132
Posted on Sunday, November 04, 2007 - 11:17 pm:
I have neither an MCI nor an Eagle. What's guy to do?
You guys kill me sometimes!
Bob Ayers (Califbob)
Username: Califbob
Post Number: 45
Posted From: 4.246.230.78
Posted on Sunday, November 04, 2007 - 11:59 pm:
Bus bolt? I belive in is aligned with the cretisfran. I recall on my 04 it never came lose because I used the spesamyfilia.
Hans (Buellhans)
Username: Buellhans
Post Number: 90
Posted From: 70.71.249.75
Posted on Monday, November 05, 2007 - 1:04 am:
personally I think the nut behind the wheel is lose . Weekend pass ? Or do you wear a hockey helmet when you are in the bus?
Ken Turner (Pipesusmc)
Username: Pipesusmc
Post Number: 81
Posted From: 71.113.39.174
Posted on Monday, November 05, 2007 - 1:43 am:
I know that guy!!!! He has a face like a wrench, everytime I look at him my nuts tighten up!
Username: Chucks
Post Number: 1144
Posted From: 68.240.90.104
Posted on Monday, November 05, 2007 - 6:58 pm:
Hey, I found it!!!
It's part number 27 in Figure 4-32 on page 4-26 of the MC9 Maintenance Manual. All it says is "Bolt", so that MUST be the one you're looking for!!!
You can send my consulting check to Livingston, TX.
I'll be waiting!
LOL
PS: Ooops, I just noticed you have an Eagle. Well, there's LOTS of bolts, but you can't tighten them, they're all rusted solid. Maybe you should leave well enough alone? Hah!
Hans (Buellhans)
Username: Buellhans
Post Number: 92
Posted From: 199.60.189.9
Posted on Tuesday, November 06, 2007 - 12:05 am:
Oh sorry its a bucket of bolts your driving thats different
Don Evans (Doninwa)
Username: Doninwa
Post Number: 87
Posted From: 66.45.165.58
Posted on Tuesday, November 06, 2007 - 11:41 am:
I think I see why there are so many loose nuts here. Y'all been turning them the wrong way, everybody knows Bus Bolts are left hand thread! :-)
Don 4107
PS: My rivets are just fine thank you very much.
Username: Pd41044039
Post Number: 209
Posted From: 69.77.146.206
Posted on Tuesday, November 06, 2007 - 2:12 pm:
This thread has me thinking that a bunch of the above contributing fasteners have been getting tight a little too often!
Jim-Bob
Post Number: 1101
Posted From: 76.66.17.103
Posted on Tuesday, November 06, 2007 - 4:53 pm:
Oh yeah.. Thanks for reminding me Jim.
A healthy slug of Molson Canadian for both the bus bolt and the bus nut should make the whole process go a lot smoother.
It may require more than one application...
buwarrior
Username: Rjlong
Post Number: 1314
Posted From: 67.181.166.160
Posted on Tuesday, November 06, 2007 - 10:45 pm:
Buswarrior -
And I'll lift a Guinness Stout to your Molson - together we shall. . . we shall. . . we shall. . .
What was it we were trying to do?
Darned multiple applications, anyway. . .
FWIW & HTH,
Post Number: 1106
Posted From: 76.66.19.38
Posted on Wednesday, November 07, 2007 - 5:03 pm:
create and solve, all of life's little problems?
