Installing Vanner Equalizer Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » November 2007 » Installing Vanner Equalizer « Previous Next »
Les Seiler (Lester)
Username: Lester
Post Number: 7
Posted From: 67.158.69.137
Posted on Saturday, November 17, 2007 - 11:59 am:
We are installing a Vanner equalizer. Does it make any difference if the equalizer is hooked with the wires coming from the batteries to the inverter? This would mean the equalizer would be hooked to the inverter same as the batteries are hooked to.
Thanks
Les
Username: Pete_rtsdaytona
Post Number: 415
Posted From: 208.118.12.229
Posted on Saturday, November 17, 2007 - 4:17 pm:
Not a problem if it's a 24 volt inverter- don't forget the Vanner 12volt connection - don't leave it hang - connect it to the 12 volt post of the 24 volt battery stack.
Big problem if it's a 12 volt inverter - Vanner will only equalize to the max amps of the Vanner (model 60-50 is only 60 amps) - that would only support a small 12 volt inverter of maybe 600 watts - over load and it pops it's C/B IIRC
Jerry Liebler (Jerry_liebler)
Username: Jerry_liebler
Post Number: 300
Posted From: 67.140.168.194
Posted on Saturday, November 17, 2007 - 9:12 pm:
Pete,
In Les's case he really isn't using the Vanner as an equaliser but rather as a source of 12 volt power for his 12 volt house needs. In his case he doesn't need to or want to connect to his 12 volt tap. He is using the Vanner as a 24 volt to 12 volt converter replacing a 12 volt converter that was powered by his 24 volt inverter, hardly efficient.
Regards
Jerry 4107 1120
Post Number: 417
Posted on Monday, November 19, 2007 - 1:14 pm:
Jerry
Your statement is only true for the older style vanner equalizers - like the 50-60 - they will function as a voltage splitter if the vanner has no 12 volt connection wired to the 12 battery post
The new Vanners family 4-5 like the 65-60 and 65-100 will not initially turn on it's 12 volt terminal (for safety reasons) if there is no 12 volt battery connection -
Reference - Doug Vanner tech support 614-771-2718
11/19/07
Pete RTS/Daytona
David (Davidinwilmnc)
Username: Davidinwilmnc
Post Number: 203
Posted From: 152.20.216.103
Posted on Monday, November 19, 2007 - 3:51 pm:
I'm curious as to why anybody wouldn't use the equalizer as intended. I pull 12 volts off the 'lower' house battery. My 24 volt inverter doesn't charge, so I have an Iota 3-stage converter (12 volt) that charges the 'higher' batter, and the 80 amp Vanner eq. keeps both batteries balanced and charged.
David
Arnie Molloy (Ayjay)
Username: Ayjay
Post Number: 84
Posted From: 68.160.182.70
Posted on Monday, November 19, 2007 - 10:13 pm:
Hi:
I'm with David above, wire it in as designed, 24 Volt charger/alternator and equalizer to the + post of the top battery, - of the top and + of the lower battery to the 12V post and 12 volt load, and gnd to gnd. Works for me!
Ayjay
