4106 Drivers side hinged window assy Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » December 2007 » 4106 Drivers side hinged window assy « Previous Next »
Jim Schrecengost (Schrec)
Username: Schrec
Post Number: 50
Posted From: 24.2.127.94
Posted on Friday, November 30, 2007 - 8:45 pm:
Can anyone tell me if the hinged drivers window glass was flat or did it have a curve to it? My 4106 has the solid curved glass and I am looking to convert to the hinged assy but getting curved glass is difficult.
Dan West (Utahclaimjumper)
Username: Utahclaimjumper
Post Number: 77
Posted From: 208.66.38.60
Posted on Friday, November 30, 2007 - 9:40 pm:
I understand that the replacement fold out type from Penninsula glass leak and rattle, and they are flat. Keeps me from wanting one.>>>Dan
Jim & Linda Callaghan (Jimc)
Username: Jimc
Post Number: 43
Posted From: 66.175.206.159
Posted on Friday, November 30, 2007 - 10:33 pm:
I have a replacement in my 4106 I don't know where the PO bought it but they have a tag on them that say HEHR or something like that.
It does not leak, and no noise that I have noticed, slides foreword so about half the window is open and it has a screen. Same type on the door.
Jim
Post Number: 106
Posted From: 66.90.229.227
Posted on Saturday, December 01, 2007 - 6:11 am:
I have Da Parts Book , and while it does show an 06 hinged drivers setup, the only place I have encountered one is on a 4104.
The Penn windows don't leak or rattle , and allow more air to circ while underway , and provide screened ventilation while parked.
BUT they don't pivot open as the 04 windows once did to attempt to catch the breeze.
The 04 requires a screen attached to the coach body to exclude bugs at speed.
And a seperate screening to be built to use when parked.
FF
Post Number: 143
Posted From: 76.4.149.200
Posted on Saturday, December 01, 2007 - 9:30 am:
gents. the 4104,4106 shucks,about all gm use the same windows for the driver and door if I am not wrong and if I am somebody follow up Please. My 4905 and 4104 are the same and will fit with no problem.
Username: Schrec
Post Number: 51
Posted on Saturday, December 01, 2007 - 4:18 pm:
I have a chance to get an original frame for a 4106 drivers window and still need to know if it is just flat glass that goes into the hinged frame.
Schrec
Douglas Wotring (Tekebird)
Username: Tekebird
Post Number: 270
Posted From: 71.59.75.212
Posted on Saturday, December 01, 2007 - 4:34 pm:
the 4104 and early 4106's had a Split pane fold open driver and door windows. The single piece glass found in late 4106's and later GM Parlor Coaches are the same and will fit in the split window opening.
to answer the first question.. The forward section of glass is curved.
I suspect if you can find someone to cut safety glass you could cut down a one peice glass as the curve is likely identicle
it is my experience that pretty nuch the only thing you get from Penn windows while going down the road is airflow out the window and noise. no know leaks from my experience unless it was an install error.
Username: Schrec
Post Number: 52
Posted on Saturday, December 01, 2007 - 5:24 pm:
Thanks doug,
So i could not have 2 pieces of flat glass put into the original frame,it would need to be curved. On a second note do you still have any windows for a 4106??
Username: Tekebird
Post Number: 273
Posted on Saturday, December 01, 2007 - 7:50 pm:
Correct the forward pane needs to be curved glass using the OEM frame.
I think I doo have driver and/or Door glass ( single pane) will have to check if you would like.
email me direct at tekebird@yahoo.com
Username: Gusc
Post Number: 551
Posted From: 63.97.117.46
Posted on Saturday, December 01, 2007 - 9:22 pm:
After reading all this string I had to go out and check my 4104 window.
As Doug says, the front half is curved. The Al frame is curved top and bottom so there is no way a flat glass will fit.
Since it is not a huge window I see no reason you couldn't bend a piece of 1/4" acrylic with heat and make it fit nicely.
Jim Rink (Fakeguy)
Username: Fakeguy
Post Number: 80
Posted From: 24.33.84.95
Posted on Sunday, December 02, 2007 - 5:57 pm:
The one I took out my 62 4106 was curved. I have replaced with Penn glass window with screen and sliding window...neither laeks or rattles and I am very happy with mine. I do miss the air flow from the curved original that open ootward at the front.
Post Number: 109
Posted From: 66.90.229.87
Posted on Monday, December 03, 2007 - 6:38 am:
I have just installed a rebuilt 04 setup and the only hassle , so far is when open forward its NOISY.
Perhaps its wind noise from an AM antenna mounted on the mirror arm. A test removal is next.
Perhaps the noise (but not too much airflow ) will go away when I mount the 04 bug screen.
FF
