Post Number: 553 Registered: 11-2005 Posted From: 63.97.117.17
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, December 05, 2007 - 8:14 pm: | |
Where can I find the by-pass thermostat, p/n 2269269, for my 4104 w/671? Probably no new ones around but a good used one is ok. |
Post Number: 228 Registered: 2-2001 Posted From: 72.242.136.203
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, December 06, 2007 - 9:43 pm: | |
I'm pretty sure nobody makes new ones any more. It actually functions backwards to the main 'stat. You may find one from one of the yards that has old GMs. |
Post Number: 554 Registered: 11-2005 Posted From: 63.97.117.34
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, December 09, 2007 - 10:06 pm: | |
Jim, You're right, I got it from two parts sources and a couple of 4104 gurus that they became obsolete ten years ago, so used is my only hope. |
Post Number: 560 Registered: 11-2005 Posted From: 63.97.117.47
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 18, 2007 - 8:28 pm: | |
Turns out I didn't even need one because my original bypass thermostat has been bypassed by a hose directly from the thermostat housing to the water pump suction side so the bypass thermostat is out of the system. It looks as if the housing was changed to allow this hose bypass to be attached in that a boss for the hose fitting was added to the housing. |
