Series 50 Transit Pumpkin? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2007 » December 2007 » Series 50 Transit Pumpkin? « Previous Next »
Post Number: 140
Posted From: 66.90.229.56
Posted on Thursday, December 20, 2007 - 12:20 pm:
A friend is stuffing a DD Series 50 into a Sportscar of Coaches (4106).
The donor transit has the pumpkin on the drivers side (looking forward from the engine) the 06 has the pumpkin on the passenger side.
It would take a lot of bulkhead carving to run the driveshaft across and use the transit pumpkin.
So he will be using the 06 pumpkin for now..
Is this the case with ALL transits ?
Or do some have the pumpkin on the drivers side (again ,from aft).
The question is because the use of a transit pumpkin will allow rear axle gear selection , and 40 years newer parts than the 06 unit.
As the HP and torque will be double , parts is always a concern.
FF
Don Evans (Doninwa)
Username: Doninwa
Post Number: 97
Posted From: 66.45.165.58
Posted on Thursday, December 20, 2007 - 1:37 pm:
"As the HP and torque will be double , parts is always a concern."
A series 50 has twice the HP and torque of an 8V71? It wouldn't be the Sports Car of Coaches, it would the Indy Car of Coaches. :-) I want one!!
Don 4107
Username: Rjlong
Post Number: 1353
Posted From: 67.181.166.160
Posted on Thursday, December 20, 2007 - 2:19 pm:
Fred -
I don't know if the pumpkin placement is the same for all V-drive transits, but it may be, since the majority use the Rockwell/Meritor unit.
The "tallest" rear axle ratio for the angle drives is the same as the ratio in the 4106 - 4.125:1. There are a bunch of lower gears available, but with the V-730, it drops the top speed even more. 4.56 and 5.38 are very common transit rear axles, with 65 and 60 mph top speeds, respectively.
S-50s run anywhere from 275 - 350hp, with torque readings up to about 1100 ft/lbs or so, not double the 8V71's numbers. As you know, several folk have stuffed a 350 hp 6V92TA in the '06 with good results, the S-50 will be similar, with a lot more shakin' at idle. The V-730 can handle that, and the '06 pumpkin should be OK with it too. Understand the 40-year newer parts thinking, that's for sure.
FWIW & HTH. . .
(Message edited by rjlong on December 20, 2007)
Username: Chessie4905
Post Number: 778
Posted From: 71.58.48.5
Posted on Thursday, December 20, 2007 - 5:14 pm:
You could put in a 4104 rear with 3:55 gears.
Paso One (Paso_1)
Username: Paso_1
Post Number: 103
Posted From: 142.165.246.239
Posted on Thursday, December 20, 2007 - 7:04 pm:
Hi RJ There was also a 4:10 combination.
I got one from Luke and he was surprised and said no wonder that Bus went like a jack rabbit. It came out of a bus he ran.
I also have a spare 4:125 which is the more common "tallist"
Post Number: 142
Posted From: 66.90.229.85
Posted on Saturday, December 22, 2007 - 6:57 am:
Anybody with a transit take a look under their bus yet?
FF
Paso One (Paso_1)
Username: Paso_1
Post Number: 104
Posted on Saturday, December 22, 2007 - 10:41 am:
FF
I have two transits here 5303 & 5307 both face passenger side one is 68 other is 77 model yr.
My spare rear end (on trailer) is 65 and also faces P/S
There is also two sizes of pumpkins for 96" and 102" wide buses.
P
Post Number: 146
Posted From: 66.90.226.233
Posted on Saturday, December 22, 2007 - 2:35 pm:
SORRY!
The question really should have been better stated.
Does anyone with a factory Series 50 in a V drive transit have the pumpkin located on the passenger side? What model bus?
FF
Paso One (Paso_1)
Username: Paso_1
Post Number: 106
Posted on Saturday, December 22, 2007 - 4:12 pm:
Thats okay FF after I typed it all I thought maybe you were looking for the answer on the newer buses. But posted it anyway in case you weren't. P
Username: Pete_rtsdaytona
Post Number: 426
Posted From: 208.118.12.108
Posted on Saturday, December 22, 2007 - 4:38 pm:
GMC RTS-II / TMC RTS-II / Flxible New Flyer / - V731 or V730 with 8V71 / 6V92 / 6V71 / L10
all have the Pumpkins in the center - with the angle drive pointed to the rear passenger side
they all use 14 bolt Rockwell 59000 V-Drive rears
available in two widths (96 and 102"
Nova RTS - Series 50 with V731RH (right hand drive) also use the same setup - center pumpkin / angle drive
Hertz and Avis RTS's with retro-fitted series 50 used STEVENSON's Reversers between the engine and the V730/V731 and the same rear end
Pete RTS/daytona
(Message edited by pete rts/daytona on December 22, 2007)
James Stacy (Jimstacy)
Username: Jimstacy
Post Number: 120
Posted From: 75.63.12.220
Posted on Saturday, December 22, 2007 - 9:47 pm:
I understand the original plan was to run the series 50 backward to solve the rotation problem. But it caused problems getting oil to the crankshaft bearings. Allison also provided an "R" option V730/731 that reversed the input rotation.
Post Number: 147
Posted From: 66.90.229.46
Posted on Sunday, December 23, 2007 - 9:32 am:
Thanks guys ,
this will have the reversing 5 speed Z-F , the final gear I believe is an OD.
With Jakes , retarder and those HUGE transit breaks , it should be able to run up or down little speed bumps like the Grapevine at close to 100mph. A real Sportscar !
FF
(Message edited by fast_fred on December 23, 2007)
Post Number: 427
Posted on Sunday, December 23, 2007 - 5:51 pm:
Many Golden Gate RTS's have right hand 6V92's into an 5 speed ZF (O/D) - same rear - middle pumpkin - angle drive pointing to Pass rear - same 14 bolt 59000 Rockwell rear axle
most have fancy commuter seats and 4.56 or 4.10 rears - with the ZF - O/D they could probably go close to 80MPH
