Roof mount A/C Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » January 2008 » Roof mount A/C « Previous Next »
Jim Schrecengost (Schrec)
Username: Schrec
Post Number: 56
Posted From: 24.2.127.94
Posted on Friday, January 11, 2008 - 9:54 pm:
I am going to be installing 2 roof mount A/C units in my 4106.....but not right away. (not enough money) However if I install the standered 14 inch roof vent can I go back and install the A/C in the same opening. I want to finish off the inside ceiling and I figured as long as I wire it for the A/C it would work.
Does anyone see anything I am not.
Thanks
Schrec
JR Lynch (Njt5047)
Username: Njt5047
Post Number: 204
Posted From: 69.132.233.230
Posted on Friday, January 11, 2008 - 10:58 pm:
A standard RV roof vent (14 X 14)will accomodate RV rooftop ACs. Just be sure that ALL the wiring necessary to operate the unit is in place.
Some units (Dometic HP for one) require 12Vdc and thermostat wiring in addition to the 120Vac supply. As long as the wiring is in place, you'll be all set to finish off the ceiling and install the ACs whenever you wish.
Another thing...if you use thermostats with "phone" looking cabling...that ain't phone cables. Most thermostats use Cat 5 cabling. Be sure of the wiring requirements of the AC you plan to use.
JR
(Message edited by njt5047 on January 11, 2008)
Username: Chessie4905
Post Number: 814
Posted From: 71.58.48.5
Posted on Friday, January 11, 2008 - 11:40 pm:
You could check the manufacturer of the AC.s you intend to use. They may have intallation instructions online.
Randy Davidson (Rdavidson)
Username: Rdavidson
Post Number: 6
Posted From: 69.19.14.39
Posted on Friday, January 11, 2008 - 11:43 pm:
I've posted this before but it is worth repeating now. A standard 14x14 is just a nominal size for reference. The actual AC unit will require, in my case for Durotherm, a 14.25 x 14.25 minumum opening. Be very careful about this. I was too literal and made them EXACTLY 14x14 -- big mistake.
Username: John_mc9
Post Number: 572
Posted From: 66.217.107.57
Posted on Saturday, January 12, 2008 - 12:17 am:
Ditto Randy's comment. 14-1/4" square is what's usually required!
Post Number: 187
Posted From: 66.90.229.32
Posted on Saturday, January 12, 2008 - 6:31 am:
On an 06 it is usual to frame with welded supports the opening chopped in the roof.
Since the carbunkle air cond will weigh 100lbs plus , and roads are not smooth , a 2 or 3 G loading should be contemplated.
FF
Username: Dnick85
Post Number: 193
Posted From: 75.196.244.245
Posted on Sunday, January 13, 2008 - 1:45 am:
Hi Jim,
I second ditto Randy's 14 1/4" square.
Good Luck
Nick-
Username: Schrec
Post Number: 57
Posted on Sunday, January 13, 2008 - 8:32 am:
The vents that I am planning on using use a rough opening of 14 1/4 ". Thanks for everyones help.
Jim
Username: Jackconrad
Post Number: 712
Posted From: 76.3.169.171
Posted on Sunday, January 13, 2008 - 9:13 am:
When deciding where to install the vent (and future AC use), remember that the AC footprint on the roof is much larger than the 14 X 14 opening. Make sure the future AC unit will clear any thing else installed on the roof such as radio & TV antennas, vent stacks, etc.
