Ed Brenner (Epbrenner)
Registered Member Username: Epbrenner
Post Number: 13 Registered: 5-2007 Posted From: 64.12.117.73
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 11, 2008 - 11:10 pm: | |
On a Eagle with a 8v71 how do you add a tach. The original alt is belt driven and not used(bad).It now has a single wire automotive type 100amp to charge crank batteries. My 4106 I used to have had a gear driven alt and I added a tach off of this. I need a tach more than a speedo. Do they make a gear driven unit with a electric sensor that can be added to the engine and use a electronic tach not mechanical. |
Post Number: 252 Registered: 8-2006 Posted From: 74.32.81.73
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 11, 2008 - 11:24 pm: | |
ED,call Precision in Phoenix they will have any thing you need and are great people to deal with 1-800-873-1055 local 602-973-1055 http://www.precisionspeed.com (Message edited by luvrbus on January 11, 2008) (Message edited by luvrbus on January 12, 2008) |
Chuck MC8 (Chuckmc8)
Registered Member Username: Chuckmc8
Post Number: 250 Registered: 5-2004 Posted From: 68.211.132.252
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 12, 2008 - 5:26 am: | |
Ed, The way to do it is with a sensor that screws into the bellhousing and monitors the flywheel teeth. Not a big job- I have a tach and the sensor that would be less than half retail $$- 14bama@bellsouth.net chuck |
Post Number: 186 Registered: 10-2006 Posted From: 66.90.229.32
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 12, 2008 - 6:28 am: | |
"I need a tach more than a speedo." What on earth for? The engine is goverened so if you haven't tampered with it , the engine should be unbreakable. For down shifting in traffic or hills simply mark the speedo with a COUPLE OF PIPS. Install one at the top speed in each gear , and you will know where to shift after slowing in traffic. KISS FF |
Post Number: 14 Registered: 5-2007 Posted From: 205.188.117.73
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 12, 2008 - 8:30 am: | |
Forgot to mention it is a 5 speed auto trans and I don't know what it is running at against the governor.Tach will be nice so I know when manually downshifting or up.Kinda hard sometimes to hear and feel it shift. |
Jack Campbell (Blue_goose)
Post Number: 55 Registered: 5-2007 Posted From: 71.101.164.147
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 12, 2008 - 8:47 am: | |
Your automotive alternator should have a output for the tach. Most of the electronic tach can be adjusted for the correct rpm's. Use your multi meter, check the outputs on the alternator for AC output. That is where the tach hooks up. Jack |
Post Number: 253 Registered: 8-2006 Posted From: 74.32.81.73
Rating: Votes: 1 (Vote!) | Posted on Saturday, January 12, 2008 - 9:05 am: | |
Ed, on the front of your 8v71 it has a tach drive looks like a speedometer drive where you can install a sensor it may still have the cover cap on it or there could also be one on the rear of the engine fwiw I have the Dixson tach with the electronic drive works great and they have a speedometer that works off the Allison the same way (Message edited by luvrbus on January 12, 2008) |
