Post Number: 198 Registered: 10-2006 Posted From: 66.90.229.92
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 15, 2008 - 6:32 am: | |
I have gotten hold of a spair 6-71 for my boat , and it has an interesting device. There is a steel heating unit set into one of the air boxes. I'm told it aids the heat output to the coach heater. True?What is the water path , what happens in summer? Also I'm looking for a WWII cold starting device . These are also inserted in an air box and are a spray and ignition source. A simple oil burner with a finger pump to pressurize some diesel, and a button to light the sparks. Anyone ever see one for sale? FF |
Post Number: 244 Registered: 2-2001 Posted From: 208.6.60.4
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 15, 2008 - 9:35 am: | |
Fred, if you need either of these items, you need a calendar & a compass more desperately! Look at the calendar, get in the sports car BEFORE a cold start device is needed and use the compass to drive to someplace where cold starts are not an issue. Jim-Bob |
Post Number: 215 Registered: 10-2004 Posted From: 12.181.45.217
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 15, 2008 - 11:16 am: | |
maybe the device in the air box is a starting aid? |
Post Number: 833 Registered: 10-2003 Posted From: 71.58.48.5
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 15, 2008 - 4:36 pm: | |
Check some military surplus sites for these Items. |
george bruton (Tazman632000)
Registered Member Username: Tazman632000
Post Number: 56 Registered: 2-2007 Posted From: 65.184.69.36
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, January 15, 2008 - 11:32 pm: | |
IVE SEEN THESE ON A SOME MARINE GEN SETS ECT. ITS PROBABLE AN AIR HEATER TO HEAT THE AIR BEFORE IT ENTERS THE ENGINE TO AID COLD STARTING |
Mike Eades (Mike4905)
Post Number: 163 Registered: 12-2000 Posted From: 68.200.183.92
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 16, 2008 - 3:55 pm: | |
Fred Forget the northeast and stay in the south. Ct will never warm up. You can keep the vw down here and I know you can the boat down here. All said and one you are starting to sound like Jim. dI HE GET the 60 put in his mci? |
Leland Bradley (Lee_bradley)
Registered Member Username: Lee_bradley
Post Number: 22 Registered: 11-2006 Posted From: 138.163.0.43
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 17, 2008 - 4:09 pm: | |
Fred, I have an Allis Chalmers manual that lists that engine pre-heater but my dozer doesn't have one. You might check at some of the antique tractor shows. When I was in the Army the Detroits used a small diesel injector and an ignitor in the air intake as a cold weather starting aid. |
Post Number: 206 Registered: 10-2006 Posted From: 71.55.6.163
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 18, 2008 - 8:38 am: | |
When I was in the Army the Detroits used a small diesel injector and an ignitor in the air intake as a cold weather starting aid. Thats what I'm looking to find!! Leads? FF |
Post Number: 284 Registered: 10-2006 Posted From: 66.90.226.240
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 05, 2008 - 7:02 am: | |
This week I pickled both the boat and spare 6-71, and got a look behind the air box cover. All the blocks (1944 and guess 1985)behind the air box cover seem to have 1 in or 1 1/4 inch plugs in the block . Seems on the transit block the plug was replaced with a short piece of pipe , with machined grove for an O ring , and a cast 2 piece cover instead of the stamped steel. The transit has two of these setups , so I guess loads of hot water was avilable to help heat a northern coach. Might be of use for other folks , looking to get more heat from the engine. Certainly looks as if they would work on the 8V , if the plugs are in that block as std. FF |
