Post Number: 120 Registered: 10-2003 Posted From: 74.244.14.221
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 19, 2008 - 7:44 pm: | |
I thought I lived in the south. We have had a good portion of snow here today about 30 miles north of Atlanta. I took this picture at 1:00 and it's still drifting down at 7:00 though not as heavy. http://members.tccoa.com/timb/snow.jpg Well since working on the bus wasn't particularly apealing in the snow I decided to work on the fresh system for it in my basement. I was trying to come up with a nice neat way to mount everything and this is what I came up with. I intend to mount this in the bay near the freshwater tank. Top valve is for using the 12v pump the bottom valve is for city water and the middle valve will be for filling the tank. It's all mounted to a piece of poly...actually a $9.00 cutting board from wally world. Any opinions or see any problems I haven't thought of? http://members.tccoa.com/timb/water.jpg Tim (Message edited by timb on January 19, 2008) (Message edited by timb on January 19, 2008) |
Post Number: 846 Registered: 10-2003 Posted From: 71.58.48.5
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 19, 2008 - 8:22 pm: | |
Is that black tank in the middle an accumulator or a filter unit? Looks nice so far. Both an accumulator and a filter unit is nice. Sears sells a filter with a replaceable cartridge that is nice and easy to service. A charcoal filter is nice for water line to faucets to get rid of odd tastes like clorine, etc.We call that snow a sapling bender up here in Pa. Probably won't last long down there. |
Jerry Liebler (Jerry_liebler)
Post Number: 323 Registered: 3-2005 Posted From: 67.141.37.60
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 19, 2008 - 9:06 pm: | |
Tim, Think of winterising the fresh water system now. How will you drain it? Will you blow out the lines & how? How will you add antifreeze? Also you'll probably want at least 18" of hose in and out of your pump for sound isolation. I chose PEX rather than copper and made a similar panel, on plywood, with my pump, city water filter and ultraviolet sterilizer on it and mounted this panel inside my bathroom vanity cabinet. I used check valves for the cty water bypass and a ball valve to fill the tanks from the city supply. My strategy on winterising is don't, so I kept all the fresh plumbing & tanks inside the upper walls and keep some heat on. Regards Jerry 4107 1120 |
Post Number: 121 Registered: 10-2003 Posted From: 74.244.14.221
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 19, 2008 - 9:13 pm: | |
John, The black tank is an accumulator. Jerry, All pipes and drain lines are in the coach so I guess there is no reason I couldn't mount this inside. All runs from the bay to the fixtures are pex (it's what the coach came with) the last owner removed the tank and cut all pex lines off with a sawsall in the bay for some reason so I am just trying to tie back into what is there. Thanks for the input Tim |
Bill McMackin (06_bill)
Registered Member Username: 06_bill
Post Number: 4 Registered: 11-2006 Posted From: 24.91.27.42
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 20, 2008 - 6:31 am: | |
Tim I would invert the pump so that a leak does not run into the motor. |
James Smith (Tomcat)
Registered Member Username: Tomcat
Post Number: 70 Registered: 8-2005 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 20, 2008 - 8:37 pm: | |
I agree with Bill, Tim. My ShurFlo 5.7 pump specifies being mounted with the motor over the pump. Jay 87 SaftLiner |
Post Number: 122 Registered: 10-2003 Posted From: 74.244.14.221
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 20, 2008 - 10:21 pm: | |
Thanks for the heads up my sureflow didn't have any documentation in the box. Easiest solution will just be to invert the entire panel (Message edited by timb on January 20, 2008) |
Post Number: 1167 Registered: 12-2000 Posted From: 76.66.19.41
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, January 21, 2008 - 12:19 am: | |
Great reminder that some consideration should be given of the water system in the coach being able to withstand some cold weather? Even for those planning to stay "south".... happy coaching! buswarrior |
