Ray Drummond (Ray_d)
Registered Member Username: Ray_d
Post Number: 36 Registered: 4-2006 Posted From: 69.105.203.55
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 30, 2008 - 3:41 pm: | |
I thought I saw a post long way back about getting all the air out when you fill the radiator, something about air being trapped. I could not find it, does anyone know about this? I have a 1989 Prevost XL with an 8V92TA. Thanks, Ray D |
Glenn Williams (Glenn)
Post Number: 129 Registered: 6-2006 Posted From: 216.163.57.205
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 30, 2008 - 4:18 pm: | |
If you have recently drained the system, yes, you will need to bleed out the air. I don't know where the bleeder fittings on a prevost are, but there will be one on the driver's heater core. If you did service work and had those lines closed witht the valves, it may not help. Good Luck! |
Post Number: 727 Registered: 12-2000 Posted From: 76.3.169.171
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 30, 2008 - 6:28 pm: | |
Not sure about a Prevost, but on our MC-8 8V71, there is a bleeder on the cross-over pipe between the thermostats on the engine and on top of the defroster heater core in the dash. There was also a bleeder on the OEM main heater core that we removed. Jack |
Post Number: 760 Registered: 10-2004 Posted From: 75.201.126.254
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 30, 2008 - 8:22 pm: | |
Call Brian Joy at 8666177386. He is the Prevost tech rep and knows the what's, not's, and the maybe's and if he doesn't know right off, he'll look it up for you on his lap top! Has helped me a bunch lately! I also have a direct number for Prevost parts and those guys really know their stuff! Ace |
Post Number: 221 Registered: 7-2006 Posted From: 4.240.213.70
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, January 30, 2008 - 8:46 pm: | |
Yes...read the Archives.... lotsa information there. FWIW RCB |
