AL (152.163.204.193)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 25, 2002 - 11:19 am: | |
I have add power steering to my eagle 10. And now I have ran into a problem I had not looked at befor I started. The steering column spline u-join is bigger than the steer box spline shaft. As close as I can measure the u-join is 1 inch and the shaft is 7/8. I think my only solution now is to find a steering column with the right size u-join. Any suggestions? Or were I can locate a steering column. Thanks to all in advance. ALbus. |
Tim Jones (Torquester) (65.100.190.84)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 26, 2002 - 7:58 am: | |
Al, Any good drive train shop should be able to make you the u-joint that you need. |
Lee Brady (Leeb11) (216.128.130.202)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 26, 2002 - 8:17 pm: | |
Al I just went thru all that,went to my local truck repair shop and got the yokes. Here are the numbers they are spicer yokes and all youll need is the universal that goes into it. for the 7/8" is 10-4-461SX yoke .870 36 spline for the 1" is 10-4-371SX yoke .994 36 spline U-joint 5170X SRI CO.940 X2. Good luck Lee 66 01 |
