Geoff Brown (04geoff)
Registered Member Username: 04geoff
Post Number: 4 Registered: 10-2006 Posted From: 97.102.35.85
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 21, 2008 - 3:56 pm: | |
Hi can anyone help me with a water pump leak at the shaft? it just slow drips when running. its a 671 DD in a 59 4104. thanks geoff |
Post Number: 590 Registered: 11-2005 Posted From: 208.54.200.168
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 21, 2008 - 7:09 pm: | |
Geoff, I have the same rig as you but have never had this problem. Based on other engines I've had this problem with my guess is that it is the pump shaft seal and I also guess the pump has to be removed to change the seal. Seems as if I remember reading on one of the bus forums that there is one bolt on the pump that requires a special wrench to remove but I may be thinking of another component. In any case I hope to follow this thread to learn something. Do you have the Maint Manual? If not I can email you the appropriate pages. |
Sammy (Sammy)
Registered Member Username: Sammy
Post Number: 80 Registered: 8-2005 Posted From: 68.237.219.157
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 21, 2008 - 7:19 pm: | |
Pump seal is bad. Pump needs to be removed and rebuilt. Hope this may help. |
Post Number: 5 Registered: 10-2006 Posted From: 97.102.35.85
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 21, 2008 - 7:46 pm: | |
Thanks Gus I do have a maint. manual but I do not have the engine manual. I would like to get an engine manual,but would love for you to email me those pages. geoffbrown211@yahoo.com geoff |
Post Number: 591 Registered: 11-2005 Posted From: 208.54.200.172
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 21, 2008 - 9:46 pm: | |
Geoff, I'll mail them tomorrow. We're having sleet & rain right now and it is too cozy here by the fire to go out to the bus. I found my DD manuals under thatbay parts & accessories. If you find one make sure it says for highway vehicle engines as most of the manuals are for trucks, generators, huge pumps and marine applications. (Message edited by gusc on February 21, 2008) |
Post Number: 6 Registered: 10-2006 Posted From: 97.102.35.85
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 21, 2008 - 10:00 pm: | |
Thanks again Gus I managed to download all the manual from PD4104.com . so know I have them all on file. Now I guess I have to take the water pump apart? Anyone know if I can get a rebuil kit for it and where? I'm in Florida at the moment. Geoff |
Post Number: 592 Registered: 11-2005 Posted From: 208.54.200.172
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 21, 2008 - 10:11 pm: | |
Geoff, Do you have the DD manual, I'm not sure if you're talking about the DD or bus manual now? Do you still need my copies? |
Tom Connolly (Tomconnolly)
Registered Member Username: Tomconnolly
Post Number: 48 Registered: 9-2003 Posted From: 71.122.121.130
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 21, 2008 - 10:55 pm: | |
Geoff, I can’t imagine why anyone would consider rebuilding the pump, A new one is very affordable. If memory serves me the bolts are 1/2", the rear one is the difficult one and requires an aircraft wrench AKA a starter wrench. it's bent in a 1/3 circle shape, you will only be able to turn the bolt a small amount before repositioning the wrench. The last time I changed one it took less than an hour to drain the coolant replace the pump and refill. I did it at a rally. Good Luck, Tom |
Post Number: 7 Registered: 10-2006 Posted From: 97.102.35.85
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 22, 2008 - 7:45 am: | |
Thanks guys, I got all the manuals for my coach so I don't need you to send me those pages. If it is not worth rebuilding? where can I get a new pump? also is it hard to get air out of system whe you refil? thanks Geoff |
Austin Scott Davis (Zimtok)
Post Number: 225 Registered: 9-2006 Posted From: 216.37.73.226
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 22, 2008 - 2:25 pm: | |
I replaced the pump on my bus about a year ago. I got mine from Luke at US Coach. Apparently there are two types of pumps so make sure you get the correct one. (one is mirror image) Anyway, everyone is correct about the mounting bolts. You will need to modify a wrench to reach the back one. I had already modified one for other reasons but it worked for this as well. I bought a open/box wrench with the box end being a 12 point NOT a 6 point. I clamped it in a vice and heated it with a torch. I bent a curve in the handle so it would reach behind to the bolt. It was an easy change-out with the curved wrench. . |
Post Number: 593 Registered: 11-2005 Posted From: 208.54.200.73
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 22, 2008 - 5:06 pm: | |
Geoff, Be sure to close the two heating line valves on the LH firewall before draining the system to keep air out of those lines. There is an air bleed petcock on top of the engine thermostat housing. This is all covered on page 123 of the Maint Manual. I just did this and the two major problems I had were that both the steel drain plug in the radiator elbow and the air bleed valve were locked up. I drilled out the steel drain plug, retapped the hole and installed a brass drain valve. I removed the air bleed valve and replaced it with a new brass one. Brass is the only way to go since it won't corrode like steel. |
Post Number: 49 Registered: 9-2003 Posted From: 71.122.121.130
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, February 22, 2008 - 10:15 pm: | |
You can google "florida detroit diesel" or follow this link http://transdiesel.net/71_series.php Most any detroit diesel shop will have the pump. |
Glenn Vining (Glennvin)
Registered Member Username: Glennvin
Post Number: 28 Registered: 10-2002 Posted From: 98.18.110.160
Rating: Votes: 1 (Vote!) | Posted on Saturday, February 23, 2008 - 10:37 am: | |
Hey Geoff, Changing out the water pump isn't that big of deal. I'd make this a priority to get it changed out ASAP. The leak from the "weep hole" is telling you that the seal is bad. It could leak like that for months, or completely fail the next time you crank it. The main thing is getting your wrench modified. After that, it's pretty much down hill. It takes about 2 hours from start to finish. Below is some things to consider. 1. If your going to try to save your antifreeze, make sure you have enough clean containers to catch it. 2. Check out the thermostat petcocks ahead of time. Make sure they work OK. If they are in bad shape, get replacements (brass) before you start. 3. Back your rig up on ramps to have more ground clearance. 4. Have a couple of gallons of antifreeze to "top off" with. As far as finding a replacement pump, it shouldn't be hard to find. I replaced ours with a Bepco unit, Cat. No BEP-7103. Here's the link to a pdf page for it. http://bepco.biz/WaterPumpCat/9-12.pdf Good luck! Glenn Tallulah Falls, GA 1959 PD-4104-4059 1984 MCI-9 |
Post Number: 8 Registered: 10-2006 Posted From: 97.102.35.85
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, February 23, 2008 - 8:07 pm: | |
Thanks guys,I will let you know how I make out. Geoff |
