102A3 door Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » March 2008 » 102A3 door « Previous Next »
Jerry Campbell (Jerrync)
Username: Jerrync
Post Number: 125
Posted From: 75.176.107.221
Posted on Wednesday, March 19, 2008 - 7:50 pm:
On my bus the door will not close to a seal. It looks good stop but going down the road it will open about 1/4 inch. The air lock will not pull the door in but will keep it from opening.how can I fix this Thanks
Glenn Williams (Glenn)
Username: Glenn
Post Number: 149
Posted From: 216.163.57.205
Posted on Wednesday, March 19, 2008 - 8:33 pm:
On my MCI 7, there is some adjustment possible for the door catch. It is hidden behind a plate that is on the catch itself. There may be one on the piston shaft itself. You may be able to take the play out. How are your door seals? If they are whipped, they would make the problem bigger. Hope this helps!
Glenn
Username: Jerrync
Post Number: 126
Posted on Wednesday, March 19, 2008 - 8:43 pm:
It does help and looking for more and my seals are not good and I am going to order them from MCI unless someone has a better price. If you know Thanks
Thomas Weeks (Buscrazytom)
Username: Buscrazytom
Post Number: 118
Posted From: 97.81.81.45
Posted on Saturday, March 22, 2008 - 8:43 am:
I saw a post on the 102A3 door closing issues written by R.J. Long not too long ago. Might want to look it up to see what, if anything, it has to offer for your situation.
BusCrazyTom
David Dulmage (Daved)
Username: Daved
Post Number: 199
Posted From: 142.46.199.30
Posted on Tuesday, March 25, 2008 - 11:08 am:
Double check to see if there is an override control in operation. On my MC-8 there is a small lever under the dash that disables the air-locking mechanism.
DaveD
