Bus rocking side to side Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » April 2008 » Bus rocking side to side « Previous Next »
Bob Baldwin (Bob4106)
Username: Bob4106
Post Number: 148
Posted From: 24.74.180.20
Posted on Wednesday, March 26, 2008 - 4:10 pm:
I took the bus out for a trip this past weekend. (GM 4106) While driving down the interstate. I could feel the front of the bus rocking side to side. It would do so for a few minutes and stop. Then start back again. Not all the time just every so often. I do have 4 new air bags and 2 new shocks. I have not got them on yet. I would like to know if I need to look at anything else while I’m under the bus replacing those parts?
Thanks
Douglas Wotring (Tekebird)
Username: Tekebird
Post Number: 319
Posted From: 71.59.75.212
Posted on Wednesday, March 26, 2008 - 7:38 pm:
while your under ou should look a everything
Post Number: 1230
Posted From: 76.68.135.151
Posted on Wednesday, March 26, 2008 - 8:17 pm:
Well... don't assume it was the front only, or that the source of the roll wasn't in the rear.
That being said, shock absorbers are supposed to dampen the bouncing of the suspension, shocks that aren't working will allow unusual body motions.
Check that all the radius rods and sway bar are properly attached at both ends of the bus.
And as tekebird suggests, everything else while you are under there too!
Username: George_mc6
Post Number: 396
Posted From: 207.231.75.253
Posted on Wednesday, March 26, 2008 - 8:55 pm:
First off, BLOCK THE BUS SECURELY AT THE JACKING POINTS BEFORE GOING UNDER, or between a tire and a fender. We want you around to give us a post back on what you find!
I'm pretty sure that your air ride system is essentially the same as mine, with one leveling valve for the entire front, and a leveling valve for each side in the rear, which govern the side to side level, and the rear height. What this means is that air moves back and forth, from side to side in the front, through a common pipe, and the only thing to slow a lurch down is the shock absorbers. Going over a bump in the back on one side, will make the front lean also...
Please also be aware that if your bus has a driveshaft handbrake, that jacking up one rear axle will completely nullify the handbrake. So, block the front wheels well before you jack the back!
HTH, and have fun, its almost springtime!
George
Post Number: 216
Posted From: 76.4.151.87
Posted on Wednesday, March 26, 2008 - 10:18 pm:
Bob, I had a 4106 and the tires caused some of my rocking. I ran radials on the front and bias on the rear. I changed the front back to bias and that solved a lot of problems along with changing shocks that eliminated all the problems. Just another thought.hmmm
gomer
Username: Bob4106
Post Number: 149
Posted on Thursday, March 27, 2008 - 8:23 am:
Thanks, It will be like a few weeks before I can get under the bus. Just though I ask to see if any one else had the same problem.
Username: Pd41044039
Post Number: 273
Posted From: 69.77.156.137
Posted on Thursday, March 27, 2008 - 10:58 am:
Bob, are you saying that the rocking has not been noticed in that bus? It is normal for GMs to rock from side to side a little, as it is normal for Eagles to rock front to back. Obviously uneven pavement, side wind & oversteering can cause rocking too.
Marvin, why didn't you change to radials all around? They'd give better mileage, ride & tread life.
Post Number: 217
Posted on Thursday, March 27, 2008 - 6:50 pm:
jim bob I COULDN"T AFFORD THEM not that I didn't want them,but when you travel and sing GOSPEL MUSIC like I still do, people think that money is given from on high and not on earth LOL. They are the ones that will pay big bucks to see their favorite team win a game or some big concert OK that is enough LOL
Gomer
P>S riverjordanmusic.com. I am the little person and the BEST LOOKING LOL
John Riddle (Jriddle)
Username: Jriddle
Post Number: 4
Posted From: 207.171.202.173
Posted on Thursday, March 27, 2008 - 9:46 pm:
Bob
I can't comment, with bus experence on rocking, but did receive e-mail from shipping company today. I will look forward to it. I not very smart on what buses will act like, but the info above sounds good to me. I had a truck one time that had mismatched tires and the thing would not go down the road till I changed tires to be the same. I also had a pickup with problems with the suspension and had same type of problems. If shocks and airbags and alinment are bad this also could be the problem.
Thanks John
Username: Rjlong
Post Number: 1367
Posted From: 67.181.166.160
Posted on Friday, March 28, 2008 - 2:26 am:
Bob -
I'd suggest you have the front tires checked at a competent tire shop. Since it comes and goes, it's possible you've got a tire either out-of-round or out-of-balance.
FWIW & HTH. . .
Username: Bob4106
Post Number: 150
Posted on Friday, March 28, 2008 - 8:36 am:
Thanks for all the input. Tires where check and ok. I was thinking if the leveling valve might have anything to do with it or maybe the ride height to high?
Username: Gusc
Post Number: 627
Posted From: 70.171.233.117
Posted on Friday, March 28, 2008 - 3:00 pm:
My 4104 definitely bounced and swayed more after changing to radials. The air pressure in the front tires makes a big difference also.
I think the swaying or rocking is normal for GM air bag systems. I call it the ocean liner effect.
Username: Bob4106
Post Number: 151
Posted on Friday, March 28, 2008 - 4:24 pm:
Not sure about being normal. I have drove other 4106, 4104 and a few other GM buses and never felt the rocking side to side before. It's not front to back or in the back, front only. I'm not sure if all the air bags on there now are even the same kind. Doug is right about looking every thing over. I was looking to see if any one had the same problem.
Username: Gusc
Post Number: 628
Posted on Sunday, March 30, 2008 - 2:56 pm:
Bob,
As I said my 4104 has done just exactly as you describe from day one and did it even more after I changed to radials. Increasing the front air pressure to about 90psi decreased it a bit but I just accept it as normal now.
All my front air bags and suspension bumpers are new so I don't consider mine a safety issue.
Username: Chessie4905
Post Number: 959
Posted From: 71.58.48.5
Posted on Sunday, March 30, 2008 - 9:22 pm:
Some of the GM coaches had dual rear shocks on them which helps. We installed a rear stabilizer bar setup on our 4104, which almost eliminates all the side to side motion. Also the more pressure in tires and more air in airbags will help this, but at a harsher and higher ride height. Also tires with fewer plys will wallow more.
Bill Gerrie (Bill_gerrie)
Username: Bill_gerrie
Post Number: 155
Posted From: 209.50.74.6
Posted on Tuesday, April 01, 2008 - 1:08 pm:
Bob
Check your ride height in the front. If your leveling valve is letting your coach ride too high it will roll. Shocks play a big part in roll as well. Use Gabriel shocks instead of Delco. They are cheaper and stiffer so less roll. If you have a rear stabalizer bar make sure it isn't broken inside the rubber bushings where you can't see it. You might want to check your tire pressure as well. Less roll if inflated harder then softer. Just a few things to look for.
Bill
Rob A (Otto)
Username: Otto
Post Number: 6
Posted From: 24.109.144.204
Posted on Thursday, April 03, 2008 - 3:36 am:
Bob,
I put up a sign...
If this bus is a rockin
Don't come knockin..
helped lots !!!
Otto
Username: Bob4106
Post Number: 152
Posted on Thursday, April 03, 2008 - 4:04 pm:
Thanks for all the help. After I change the air bags and shocks plus looking around for any other problems. I'll come back with a report
