Barry McCully (Turtle)
Registered Member Username: Turtle
Post Number: 15 Registered: 8-2007 Posted From: 71.7.213.91
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 30, 2008 - 2:42 pm: | |
I posted an early question an I'm going to try to go with the wiremold but does anyone know if it is OK to drill a small hole in the roof supports just for the wire for the roof air. |
Glenn Williams (Glenn)
Post Number: 150 Registered: 6-2006 Posted From: 216.163.57.205
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 30, 2008 - 6:39 pm: | |
Not a problem at all. That's exactly what I did. Good Luck! Glenn |
Post Number: 590 Registered: 7-2006 Posted From: 66.217.100.57
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 30, 2008 - 7:29 pm: | |
Thru the beams.... Prolly b'best to use some sort of insulating grommet (pvc tube, rubber hose, or whatever), to keep the wire from chafing against the bare metal hole, ehh? Road vibration can play hell! I suggested the "WireMold", assuming the ceiling was intact, but if the ceiling's off, thru the beams would be neater. It's easier to add wires later with the WireMold, but big holes and a pull-string left in, can help with the "thru the beam" approach! Cheers! |
Post Number: 741 Registered: 12-2000 Posted From: 99.204.98.50
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 31, 2008 - 5:50 pm: | |
There should already be some holes through the roof bows that were used for speaker wires. Jack |
