Oil Consumption Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » April 2008 » Oil Consumption « Previous Next »
Buddy Tennison (Buddyten)
Username: Buddyten
Post Number: 58
Posted From: 207.68.234.24
Posted on Monday, April 07, 2008 - 10:54 am:
Hey Guys:
It is me again with another of my questions.
To bring you up to speed on what I have:
83 Eagle with 8V71 and 5 speed tranny
Had a ring job, inserts, etc about 15-20K ago. Mechanic checked all the parts and told us that everything seemed to be good and within allowable tolerances. He also told us that because we don't put a lot of continuous driving miles that it would take a while for break in, and that oil consumption would be a little higher than normal. We have been running now about a year. Our mechanic has since had some major health problems and is disabled and closed his shop. Have not been able to talk to him much about it.
Very little to no smoke except on start up and under a load. Very little oil on the back of the bus to indicate blow by. People who have followed us confirm little or no smoke. We have observed no leaks to speak of, and the slobber tubes are no putting out a lot of blow-by. Engine runs really good. Plenty of power. Oil pressure stays around 48-60 psi pretty consistently, dependent on where we are driving. (In high gear, out on fairly flat roads, Oil pressure stays around 50-55)
Problem is, we are using about a gallon of oil every 400-500 miles, and sometimes more than that. We are using Shell Rotella 40W as some of you have suggested.
Where is the oil going?? If it was burning that oil, shouldn't there be the tell-tale smoke, etc? We have noticed that on the driver side, around where the slobber tube is, there seems to be a lot of "wet oil" on the engine, but at idle (either normal idle or fast idle), there is not much slobber coming out. We are getting ready to change oil and filters this week to see if that helps. Should we use a different brand/weight of oil? Any suggestions would be very much appreciated.
Username: Luvrbus
Post Number: 343
Posted From: 74.33.36.66
Posted on Monday, April 07, 2008 - 11:08 am:
Buddy, I would change brands of oil I have a 8v92 in my Eagle and it does not like the Rotella uses a gal about every 1000 miles and I would also see if it makes any difference if you leave it about 1/2 gallon low does your engine have the check valves on the drain tubes.I use Delvac or DD oil(same oil) now and use a gal about every 3000 miles good luck
(Message edited by luvrbus on April 07, 2008)
Laryn Christley (Barn_owl)
Username: Barn_owl
Post Number: 316
Posted From: 72.66.181.54
Posted on Monday, April 07, 2008 - 11:16 am:
Exxon's XD-3 40wt is another very good oil for the DD TS and usually easier to get.
Username: Luvrbus
Post Number: 344
Posted on Monday, April 07, 2008 - 11:33 am:
BarnOwl, I think that is the same oil as the Delvac and the DD oil good stuff
Username: Buddyten
Post Number: 59
Posted on Monday, April 07, 2008 - 12:47 pm:
Thanks guys:
What name brand is Delvac or DD oil? We get the Rotella from the local Shell distributor, but I have never heard of the Delvac. Where is the best place to get it?
Username: Luvrbus
Post Number: 345
Posted on Monday, April 07, 2008 - 12:56 pm:
Buddy, Delvac is Mobil\Exxon so is the Detroit Diesel brand of oil
Username: Niles500
Post Number: 832
Posted From: 71.42.167.154
Posted on Monday, April 07, 2008 - 2:03 pm:
You may want to try letting it run about a half gallon low and see if your consumption goes down - this has worked for others - HTH
Username: Chessie4905
Post Number: 997
Posted From: 71.58.48.5
Posted on Monday, April 07, 2008 - 5:40 pm:
Did he install piston and liner kits or just new rings on the old pistons? When it is hot and idling, is the exhaust clear or with a very slight light black haze OR is it somewhat bluish until you speed it up? What color is the smoke under a load. Should be a little black and then completely clean up above 1700 or so. What size injectors? The one thing with Detroits or for that matter all diesels, they run good or better even if they burn oil. Many old jimmy drivers said they ran the best right before they blew up.( needed rebuilt). High oil level could be your problem or might need more miles to break in; especially if old liners and pistons were reused. Also if reusing the liners, thehoning cross hatch could be improper.Can take 10,000 miles to completely seat rings if it has been driven easy all the time. Even so, the oil consumption should gradually drop over the break in miles if the parts are ok, except, of course the oil level being too high. The one problem with cheap off brand liner and piston/ring kits can be poor oil control after break in due to lower quality materials. He might have broken a ring or two during installation. This could be checked by removing inspection covers and checking each ring for proper tension. Unfortunately this is nearly impossible in some coaches.
Donald P Hann (Eagle19952)
Username: Eagle19952
Post Number: 3
Posted From: 98.196.153.247
Posted on Monday, April 07, 2008 - 6:13 pm:
Chevron Delo 100 works well too.
James Robinson (Jjrbus)
Username: Jjrbus
Post Number: 119
Posted From: 68.243.1.135
Posted on Monday, April 07, 2008 - 6:41 pm:
Good info here. It seems odd that the same engin with the same dipstick would start throwing out oil. Is it possible the dipstick/oilpan was changed? Out of the options you have the simplist one is to run it a 1/2 gal low and see what happens.
Post Number: 1002
Posted on Monday, April 07, 2008 - 7:05 pm:
he might be adding " extra oil " everytime he checks it so it doesn't get too low. The crank is close enough to the full pan that it whips it into a small hurricane that the rings have a hard time dealing with.
Username: Luvrbus
Post Number: 346
Posted on Monday, April 07, 2008 - 7:44 pm:
Buddy,I am not a DD expert but have a friend that is he said make sure you don't have to much oil he said the engine should hold + or- 7 gals and if that is not the problem it is more than likey the guy forgot to check the piston pin retainers with the vacuum tester at 10in or you could have bad valve guides good luck on this
Username: Dreamscape
Post Number: 253
Posted From: 75.145.74.185
Posted on Monday, April 07, 2008 - 8:34 pm:
I learned the hard way that you need to let the DD sit for at least one hour before checking your oil level, takes a long time to drain down. Also our 8v71 really likes it when it's half gallon low, and it stays there for quite a while. It does not like to be topped off. Although I don't really know the internal situation on wear with ours, this is what has worked so far.
James Stacy (Jimstacy)
Username: Jimstacy
Post Number: 131
Posted From: 76.228.61.248
Posted on Wednesday, April 09, 2008 - 9:49 pm:
"full" mark on dipstick should be 1" below pan gasket. There were many different sticks and tubes available. They often got mixed up.
Post Number: 287
Posted From: 66.90.226.172
Posted on Thursday, April 10, 2008 - 5:28 am:
"I learned the hard way that you need to let the DD sit for at least one hour before checking your oil level,"
Da Book I have sez 5 min.
For anyone attempting to run low on oil as a leak preventive , be sure to monitor the oil pressure .
If the pressure bounces at cruise , thats AIR , instead of oil "lubing" your engine!
Far easier to pour in a bit of oil than slip in a new crank, rods and bearings.
FF
Post Number: 1012
Posted on Thursday, April 10, 2008 - 5:13 pm:
I liked the setup on the Brill I had. It had a small round glass window to maintain the oil half way up the glass. It had a scavenging pump and put the oil into a separate section with that window. Probably many people put in extra oil so they don't have to add so often, causing more trouble with leaks and excessive consumption.
Bob Symonds (Bob_symonds)
Username: Bob_symonds
Post Number: 35
Posted From: 146.235.66.52
Posted on Thursday, April 10, 2008 - 7:58 pm:
I have a 4104 and I run it 1/2 gallon low. It never needs oil unless I top it off then it will "loose" that 1/2 gallon somewhere.
