jme (63.24.112.125)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 27, 2002 - 3:44 am: | |
Are the side windows and/or bay doors compatable over a range of models? From some photos I see it seems as if they just might. I read a post from Doug stating the gaskets from windshield glass should be usable from post 4104 models provided you had a single piece of glass up there. We have a 4104. Thanks , JME |
Jim Stacy (12.87.108.209)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 27, 2002 - 3:21 pm: | |
All GM intercity buses from 4104 to 1980 use the same windshield. This glass is the same right and left and was also used in many 96" Prevosts as both windshield and side glass. Obviously some Prevosts had dark tinted side glass that should not be used as windshields. Most of the bay doors and paneling are unique to a given model due to floor height and rib pattern. Much of the drive train and steering was interchangeable from 4106 on. The '04 used a different steering box, air bags and V drive. This was redesigned for the automatic transmission starting with the '06. HTH Jim Stacy |
