Buddy Tennison (Buddyten)
Post Number: 60 Registered: 7-2005 Posted From: 207.68.234.24
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 22, 2008 - 9:34 am: | |
Hey Guys: Where (typically) is the sending unit for the oil pressure guage located on the engine (8V71), and what does it look like? Is it electrical or mechanical? Does it go bad? How hard is it to replace? Thanks for all your help. |
Laryn Christley (Barn_owl)
Post Number: 376 Registered: 10-2006 Posted From: 72.66.181.54
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 22, 2008 - 9:53 am: | |
I believe it depends on your bus manufacture. For example, on the GM 4106, it is located on the bulkhead beside the mechanical oil pressure gauge. |
Glenn Williams (Glenn)
Post Number: 155 Registered: 6-2006 Posted From: 216.163.57.205
Buddy, What make and model bus do you have? They are not always directly mounted on the engine. For example, on my MCI7, it is on a manifold on a frame rail. Mine are electric, just about an inch and a half in diameter and it just spins into the manifold with one or 2 wires attached. Good Luck! |
Ed Jewett (Kristinsgrandpa)
Post Number: 374 Registered: 2-2003 Posted From: 64.24.208.219
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 22, 2008 - 9:58 am: | |
Reread his post, he is looking for the sending unit, not the gauge. Ed |
Post Number: 359 Registered: 8-2006 Posted From: 74.33.59.166
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 22, 2008 - 9:59 am: | |
Buddy,the Eagles on the drivers side in the engine compartment they have a block that has a line ran to it close to where you grease the fan it will have some wires and should have a mechanical gauge there also if not it will have plugs to install one, the dash gauge is electrical and the sending unit for the dash along with the low oil pressure shut down is located on that on that block and they do go bad and if you do not have a mechanical gauge there I would install one for a accurate reading good luck (Message edited by luvrbus on April 22, 2008) |
