dougthebonifiedbusnut (24.218.119.24)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 28, 2002 - 9:18 pm: | |
hey fred or any other wiring gurus i am wiring my elec tach and speedo and am told that it is aood idea to use shielded wire 1 is there such a thing as stranded shielded wire 2 i am only going 25' so am i worrying to much 3 does the shield have to be connected as a ground to work i really want to use regular 12 gauge wire cause its pretty complicated routing to get them connected as always, preciat the help |
jmaxwell (66.42.92.137)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 28, 2002 - 10:11 pm: | |
Wether or not u need shielded wire depends on the manufacturer, some call for it, some don't. I think a lot of this depends on the signal source. My VDO stuff does not need shielded, but other VDO that I have seen is shielded. My former Motorola Speedo rqd. shielded. Also, u do not need 12ga., 16 is usual, and 18 is probably sufficient. Both are available in multi-conductor shielded at most electronic supply places. |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 29, 2002 - 6:29 pm: | |
thanks j i think i will take my chances and go with the unshielded 16 gauge the manufacturer does not specify but i heard it was a good idea to use thew shielded wire will tell you how they work i agree i meant to say 16 or 18 gauge |
David Anderson (168.215.176.128)
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 29, 2002 - 11:07 pm: | |
I am wiring a VDO tach gauge and the tech at VDO didn't mention shielded wire. I am using a magnetic inductive pickup sender on the bottom of the transmission bell housing that counts flywheel teeth. Couldn't get it to work off the R terminal of the alternator. VDO couldn't tell me the dip switch setting for my Eagle with a miter box. He did tell me to run the ground from the pickup all the way back to the tach and ground both in the same place. When I get it hooked up I'll let you know how it works. I've been waiting 3 weeks to get the sender from VDO. Their parts distribution is pretty poor If your sender has a ground and your tach has a ground, you might want to ground both in the same place, also. |
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 30, 2002 - 5:26 pm: | |
thanks dave my sender and sensor are amatech and my gauges are dixons so i have opted to just run 16 ga speaker wire im going to just run a short ground to a convienient spot as it seems to me a longt ground wire would act like an antenna and pickup some interferance ill keep in touch and tell you how it works got to do my one weekend a month this weekend so ill probably have it done around wednesday |
