Roger Dalke (Roger_d)
Registered Member Username: Roger_d
Post Number: 8 Registered: 8-2007 Posted From: 205.206.150.244
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 25, 2008 - 12:19 pm: | |
How are coaches ventilated after conversion? Are the wall vents retained? I will be re-skinning my 7 and don't want to build a stuffy interior but also would like it vented without having to always have a window or roof vent open. Ideas? Thanks, Roger |
Don Evans (Doninwa)
Post Number: 118 Registered: 1-2007 Posted From: 208.81.157.90
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 25, 2008 - 1:15 pm: | |
Hard to beat one (or more) of the fan systems or covers that mounts over or replaces a regular RV vent. We leave it open year round with never a worry about rain or moisture. Something like TurboMax or Fantastic Fan. They may not be the most attractive thing you can add to the coach but they work. TurboMax is what we use. Ugly but no worries about leaking or whether the automatic closing system (Fantastic Fan) works or is turned on like during winter storage. Don 4107 |
Post Number: 299 Registered: 10-2006 Posted From: 72.64.23.147
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 25, 2008 - 4:10 pm: | |
When a forward window is open the air moves from the rear of the coach out the open front window. So be sure to use J traps on all your waste connections or you will smell S**T. FF |
Post Number: 1054 Registered: 10-2003 Posted From: 71.58.48.228
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 25, 2008 - 5:06 pm: | |
smell S**T?.... soot? snot? sent? ( spelled scent )....oh well, I wasn't very good at Scrabble anyway. |
Post Number: 267 Registered: 7-2006 Posted From: 4.240.214.177
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 25, 2008 - 9:00 pm: | |
FF.... curiosity.... I have been thinking about this for a while and frankly do not understand a thing or two. ( Could it really be age? ). Our coach has two front roof vents,no fans in the roof, two in the mid section... both have fans, and two rear, with fans... (exhaust). When we open a front window, the fans run.... How does that meld with your post? Thanx, RCB |
Tony LEE (T_lee)
Post Number: 27 Registered: 11-2007 Posted From: 90.39.185.130
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 27, 2008 - 2:28 am: | |
Your vents probably have some permanent ventilation built in so that with the front window open, the low pressure there sucks air through the rear vents at a fast enough rate to make the blades windmill. |
Post Number: 269 Registered: 7-2006 Posted From: 4.240.213.220
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, April 27, 2008 - 10:52 am: | |
"Our coach has two front roof vents,no fans in the roof, two in the mid section... both have fans, and two rear, with fans... (exhaust). When we open a front window, the fans run...." Sorry, not well stated...what I meant was we turn the fans on in the rear to "effectively" pull air from front to back......OR? RCB |
Post Number: 306 Registered: 10-2006 Posted From: 208.100.193.188
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 29, 2008 - 4:00 pm: | |
The front drivers window is in a low pressure area caused by the "bow wave". Probably your roof vents are further aft , out of the low pressure zone. FF |
Post Number: 270 Registered: 7-2006 Posted From: 4.240.214.183
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 29, 2008 - 8:55 pm: | |
Thanx FF.... 's what I thot...RCB RCB |
