george bruton (Tazman632000)
Registered Member Username: Tazman632000
Post Number: 68 Registered: 2-2007 Posted From: 65.184.236.52
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 01, 2008 - 9:40 pm: | |
i just swapped engines out i my coach the engine i put in has the jake brakes with tall valve covers the the lower cover is hitting the tail gate so i cant get it to shut, what have ther people done to get it to close? looks like i might have to cut the tail gate out then build some thing to go over it but i hate to cut a stock tail gate? |
Douglas Wotring (Tekebird)
Post Number: 350 Registered: 10-2004 Posted From: 71.59.75.212
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 01, 2008 - 10:14 pm: | |
you have to cut it and put a buldged out section. |
Geobus (4108gmc)
Registered Member Username: 4108gmc
Post Number: 72 Registered: 6-2004 Posted From: 74.213.213.175
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 02, 2008 - 9:49 am: | |
For a short term fix, I took 2 2x4 blocks and fastened them to the base of the vertical hangers that hold the engine. I set them on the bumper and fastened them to the uprights. These blocks hold the door away from the valve cover. However, you will need to use a bunge to strap the door shut. This should buy you time until you modify the door. Have a great day. |
Mark Renner (Boomer)
Post Number: 93 Registered: 11-2006 Posted From: 12.180.53.193
![](http://www.busnut.com/bbs/messages/thumbnails/20197.jpg)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 03, 2008 - 1:24 pm: | |
Doesn't R&M Fiberglass make a 4106 tailgate panel that will work for this application? |
Tom Christman (Tchristman)
Post Number: 15 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, September 06, 2008 - 5:10 am: | |
I had a panel covering my valve cover that I just removed and the valve cover now is exposed, but the rear door shuts fine. I like seeing the valve cover. Good Luck, TomC |
