Towing Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » June 2008 » Towing « Previous Next »
Ed Dezz (Sundezz)
Username: Sundezz
Post Number: 7
Posted From: 66.18.214.184
Posted on Sunday, June 01, 2008 - 8:57 am:
Hi there, my name is Ed Dezz long time member
mostly a reader of this board,great info. Can i
tow a 06 4x4 chev pu with auto trans, 4 down?
don (Bottomacher)
Username: Bottomacher
Post Number: 171
Posted From: 72.15.86.59
Posted on Sunday, June 01, 2008 - 9:43 am:
Read the owner's manual for the truck to determine; they are the best source.
Larry & Lynne Dixon (Larry_d)
Username: Larry_d
Post Number: 145
Posted From: 71.111.188.44
Posted on Sunday, June 01, 2008 - 12:21 pm:
Ed try doing search on Camping World towing 4 down, they will tell what can and can't tow. There list goes back five or six years and you can buy futher back. Happy towing 4905 Larry
Username: Luvrbus
Post Number: 410
Posted From: 74.33.56.175
Posted on Sunday, June 01, 2008 - 12:55 pm:
Ed, the FMCA web site has information on vehicles for towing 4 down also
(Message edited by luvrbus on June 01, 2008)
Username: Chessie4905
Post Number: 1169
Posted From: 71.58.48.228
Posted on Sunday, June 01, 2008 - 1:01 pm:
the quick answer is; yes, if you have a neutral position on your 4 wheel drive shift lever or button. If it is pushbutton type, most can't be, although one or two can engage neutral by pushing the correct two buttons at the same time. You need to get the model number off the transfer tag to be sure.If you still have the owner's manual, it explains which ones that can be towed 4 down.
Post Number: 1170
Posted on Sunday, June 01, 2008 - 1:05 pm:
check here: http://www.motorhomemagazine.com/output.cfm?ID=1073647
Chuck Newman (Chuck_newman)
Username: Chuck_newman
Post Number: 266
Posted From: 63.145.177.245
Posted on Tuesday, June 03, 2008 - 2:30 pm:
Ed, the MotorHome and FMCA listings are your best source of information. I have found the owner's manual, on newer vehicles, are not real clear about this issue if they don't recommend it. On the models that are towable, they have been clear and to the point on the three models I have towed 4 down.
