Oil leak Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » June 2008 » Oil leak « Previous Next »
Barry McCully (Turtle)
Username: Turtle
Post Number: 20
Posted From: 24.89.235.12
Posted on Monday, June 02, 2008 - 1:58 pm:
I have an MC-9 with a 8V71 with and auto.and I'm getting quite an oil leak where the oil cooler bolts on to the engine is there a gasket kit for this or any ideas.
Thanks
Username: Luvrbus
Post Number: 411
Posted From: 74.33.56.175
Posted on Monday, June 02, 2008 - 2:09 pm:
Barry, there is a gasket for the front cover and behind the oil cooler call a DD dealer with the serial number off your engine and he will have it,man is that a nasty job remember to drain you cooling system and there are some bolts on the inside of the cooler forgot to tell you but if the transmission is running through that cooler you will need 2 of each on the gaskets good luck
(Message edited by luvrbus on June 02, 2008)
Iver (Mciv)
Username: Mciv
Post Number: 19
Posted From: 70.69.141.210
Posted on Tuesday, June 03, 2008 - 3:13 am:
Is the leak coming from the gasket joint? Sometimes, the leak can be from one or more bolts. I had one bolt which must have had the threads tapped into the oil gallery and the oil leaked around the bolt. I removed the bolt and added a copper washer, tightened it down and no more leak. HTH.
Iver.
