Best welder for this generator Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » June 2008 » Best welder for this generator « Previous Next »
Joe (Frtnkr)
Username: Frtnkr
Post Number: 54
Posted From: 69.27.77.146
Posted on Tuesday, June 03, 2008 - 6:32 pm:
My question is not exactly related to my bus but I figgured that a few of you had a lot of experience with generators and welders...
I have no access to power where I am working other than a generator, and was wondering if any of you all know of any mig welders that will do 3/8 in steel with gas that will work with this limited power supply. The generator is a Yamaha YG 450 D. It will safely put out 3600W at 110V/30A at 110V or 15A at 220V (according to yamaha tech support). Thanks, Joe
Username: George_mc6
Post Number: 460
Posted From: 207.231.75.253
Posted on Tuesday, June 03, 2008 - 11:47 pm:
3/8 of steel is quite a bit for a small wire welder...
Sashay down to your nearest Home Depot, or Harbor Freight, etc, and read the labels.
G
Username: Joemc7ab
Post Number: 268
Posted From: 66.38.159.33
Posted on Wednesday, June 04, 2008 - 12:37 pm:
Joe
A welder that can handle 3/8 would require 5.5 kw. I am looking at the millar catalog for the 210 millarmatic.
To handle 5/16 you would need 4.1 kw, which is the maximimum draw of the 180 series, which makes it close to your powersupply capability.
Last year I looked at buying the 210 but settled for the 180 and spent a thousand less in the process.
Joe.
Joe (Frtnkr)
Username: Frtnkr
Post Number: 55
Posted From: 75.139.7.183
Posted on Wednesday, June 04, 2008 - 6:05 pm:
Well I did some more looking around and this is what I found, The Ready Welder II. Best part is...No generator required! Check it out...
http://www.readywelder.com/
I may order it next week, if so, I'll let you all know how it turns out.
Joe
Username: Joemc7ab
Post Number: 269
Posted on Thursday, June 05, 2008 - 3:41 pm:
Joe
But how are you going to recharge the batteries, once they are run down?
Joe.
Username: Pvcces
Post Number: 1208
Posted From: 65.74.72.93
Posted on Thursday, June 05, 2008 - 9:47 pm:
We can provide batteries and recharging for these, but I would like to know if these welders work very well.
Suncatcher
Ketchikan, Alaska
Post Number: 462
Posted From: 76.91.197.153
Posted on Thursday, June 05, 2008 - 11:54 pm:
Thanks Joe for saying it first! According to what I read, 3/8 steel will require 36 Volts, which of course is three 12 Volt batteries in SERIES. I think it also required about 300 amps for that thickness? Pulling 300 amps out of 400 amp hour batteries, is going to run them down in about half an hour. Recharging them in parallel with a 100 amp charger, will take over 12 hours.
I know, you don't have shore power, I read the posts, I just haven't quite figured this out yet.
Where's the free lunch?
George
Username: Kyle4501
Post Number: 428
Posted From: 65.23.106.193
Posted on Friday, June 06, 2008 - 11:54 am:
I'd suggest finding an old (gas, propane or diesel) welder that's still serviceable. The new welders are much smaller than the old stuff - which makes the price on old stuff a little easier for us occasional users :-)
These welders usually can generate plenty of extra electricity for running air compressors & lights :-)
When you're done with the project, you can always sell it & recoop some of your $$.
BTW, a good welder isn't cheap. When I bought my Millermatic 172 (new & it plugs in to 220V), I had ~$1000 in it after buying the gas bottle, ground clamp, gloves, consumeables, helment, etc. The little things added up!
Joe (Frtnkr)
Username: Frtnkr
Post Number: 56
Posted on Wednesday, June 11, 2008 - 12:59 pm:
George,
You need 36V to weld 1/2".
Guys, We got the welder Monday, and only had a few minutes to use it. With two old deep cycles, we had no problem welding 3/8 material with 24V. We are going to pick up two gel core deep cycles and a 24V 100A alternator for the truck today. I'll keep you posted.
