Rob Pacella (Rap16823)
Registered Member Username: Rap16823
Post Number: 8 Registered: 8-2007 Posted From: 12.177.54.235
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 05, 2008 - 1:06 am: | |
I would like to hear how some of you have installed Fiberglass sides on your conversion. Do you back it up with wood, go over the metal? I read the archives and do not see much other than a lot of talk about rivets and the removal What about the strength issue. This is on a MCI 102C3 |
Post Number: 418 Registered: 8-2006 Posted From: 74.32.83.242
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 05, 2008 - 12:10 pm: | |
Rob, call Richard at R&M the guy that makes the stuff and he will give the info you are looking for he does it every day 1-800-350-1656 |
chris cooper (Ccoop)
Registered Member Username: Ccoop
Post Number: 5 Registered: 11-2006 Posted From: 68.229.149.78
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 05, 2008 - 5:27 pm: | |
I would never install fiberglass siding again, on the upper section I used a single large sheet that was stretched tight and glued to the frame work. soon after installation it statred to warp between each frame member, luckily inward so I let it set for a few months to let it settle then I spayed the inside with foam then the entire outside had to be faired in with a marine compound. this was an extreme amount of work. the middle section was installed as per r&m recomendations and it has done pretty well. now after about 4 years it is still changing shape in some areas. NEXT TIME I WILL USE 1/8 ALUMINUM |
Registered Member Username: Davidanderson
Post Number: 233 Registered: 2-2004 Posted From: 69.153.76.148
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 05, 2008 - 6:05 pm: | |
Wow Chris, I didn't have any problem like that on my eagle10. I got mine for R&M, also. I stretched mine out and shoved it under the roof skin at the top window rail, then glued it all down with urethane caulk. 8 years now and no problems. I can't imagine what went wrong with yours. David |
Ron Walker (Prevost82)
Post Number: 373 Registered: 11-2003 Posted From: 208.181.210.47
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 05, 2008 - 8:05 pm: | |
I haven't had any problems with my fibeglass sides. They 5 yrs old now. Ron |
Post Number: 613 Registered: 7-2006 Posted From: 66.217.106.87
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 05, 2008 - 8:23 pm: | |
After having a small tree's twig penetrate both the outer fiberglass siding, and the inside paneling of a Winnebago, I swore I'd never want a fiberglass outer shell on an RV again..... Aluminum is tough! Aluminum panels are easy to install, with no special gluing process involved. It can be removed easily, can be fastened to (as in: awnings), and is easy to paint (no gel-coating).. But hey.... We all do it "our way".. There's no right or wrong. |
Post Number: 9 Registered: 8-2007 Posted From: 12.177.54.235
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 09, 2008 - 9:58 pm: | |
I wanted to use Aluminum but right now metal is very over priced, Does anyone have a place to get long peices of aluminum. I did not want any seams. Thanks for all the feedback |
