Joe (Homermandy)
Registered Member Username: Homermandy
Post Number: 43 Registered: 11-2006 Posted From: 198.151.12.8
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 06, 2008 - 1:28 pm: | |
1991 Eagle. When the bus is moving, not sitting still, when you make a hard turn left all the way, as the wheel turns back to center there is a grinding/clunking noise near the front left tire. Kind of like something is binding. I checked and greased all fittings I could see in the front. The problem does not exist if I am sitting and turning the wheel, as well as full right turns back to center. Any ideas? Thanks |
Don Evans (Doninwa)
Post Number: 123 Registered: 1-2007 Posted From: 208.81.157.90
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 06, 2008 - 3:35 pm: | |
Joe, Did you jack up the wheel and check the bearings and king pin? Good luck Don 4107 |
Joe (Homermandy)
Post Number: 45 Registered: 11-2006 Posted From: 24.210.164.208
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 08, 2008 - 2:55 pm: | |
Posts: 85 View Profile Email Personal Message (Online) Re: Eagle 15 Front End Noise Question « Reply #11 on: Today at 12:56:35 PM » Reply with quoteQuote Modify messageModify Well, I was under the front end and after checking for all zerks, I did find one zerk which had worked its way out a little. Not sure what front end part you would call it, but it is near the tire and has zerks on both sides of the metal piece. I had to reinsert and tighten the zerk, and it took quite a bit of grease. Took it for a spin and the sound is gone. Thanks for the help and I hope the sound does not come back. |
