Light Problem Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » June 2008 » Light Problem « Previous Next »
Buddy Tennison (Buddyten)
Username: Buddyten
Post Number: 69
Posted From: 207.68.239.252
Posted on Monday, June 09, 2008 - 10:53 pm:
Last evening on our trip home, out of the blue, the dash lights, and the side marker lights started a very faint "blink". When I shut the engine down, you could hear a clicking sound much like the sound with the hazard light or turn signal light. Is this a relay going out? If so, are these readily available at a parts store. If it is not a relay, would would you think it would be?
Username: Dreamscape
Post Number: 283
Posted From: 70.167.209.179
Posted on Monday, June 09, 2008 - 11:41 pm:
It could be a loose wire, bad ground or a poor connection. I would think it if was a relay they usually just go out. I would check your wiring and grounds first. Do you have a manual so you can find wire numbers? That would be a good way to start your troubleshooting. If they are on the same circuit, you have a good start. Maybe someone with a later model Eagle can help.
Good Luck
Paul
larry currier (Larryc)
Username: Larryc
Post Number: 179
Posted From: 207.200.116.13
Posted on Monday, June 09, 2008 - 11:54 pm:
Sounds like a circuit breaker is getting hot and breaking the circuit. Feel it for heat and find out what is shorting out.
James Robinson (Jjrbus)
Username: Jjrbus
Post Number: 132
Posted From: 99.206.10.19
Posted on Tuesday, June 10, 2008 - 7:49 am:
Does sound like a circut breaker. If it is not a short in the system then the breaker is going bad. Non electrician fix is replace breaker if it contiues to happen then you have a short and a spare breaker. You should be able to find offending breaker by following sound or sometimes feeling the breakers.
