Carbon monoxide detectors Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » June 2008 » Carbon monoxide detectors « Previous Next »
RJmule (Rjmule)
Username: Rjmule
Post Number: 146
Posted From: 76.254.142.45
Posted on Tuesday, June 10, 2008 - 11:41 am:
Would anyone know if these would be suitable for a bus conversion. Thanks.
Re: (2) firex carbon monoxide detector with battery back-up (each) - $15 (orange county)
Username: George_mc6
Post Number: 463
Posted From: 207.231.75.253
Posted on Tuesday, June 10, 2008 - 2:30 pm:
RJ,
Apparently what you are describing are household type CO detectors. If so, they are designed to run on 120 VAC, and on battery for only a short time during power failures. They will work fine in a bus, but take the batts out before you leave it for the winter, or they will be dead, and tend to leak and ruin things. Also, these will cause an inverter with idle feature to run in power all the time, for what that's worth.
G
Username: Chessie4905
Post Number: 1181
Posted From: 71.58.110.9
Posted on Tuesday, June 10, 2008 - 5:33 pm:
Check with Camping World to see what they offer.
Username: Jackconrad
Post Number: 773
Posted From: 76.3.173.51
Posted on Tuesday, June 10, 2008 - 6:28 pm:
You are better off to get CO detectors that operate off 12 volt DC for the reasons mentioned above as well as 12 volt DC models are made for vehicles and can better handle bumps, jolts and vibration associated with traveling. Jack
PS: follow the installation instructions. Installing it in the wrong location can make it useless. Jack
Username: Bigrigger
Post Number: 82
Posted From: 24.197.246.104
Posted on Tuesday, June 10, 2008 - 11:44 pm:
I just bought 2 combination smoke detector and co detectors for $40 and change on sale at Menards (ie Home Depot, Lowes, etc) they arent that expesive and came with new alkaline batts also.
RJmule (Rjmule)
Username: Rjmule
Post Number: 147
Posted on Wednesday, June 11, 2008 - 9:54 am:
thank you all for your informative advice.
