george bruton (Tazman632000)
Registered Member Username: Tazman632000
Post Number: 73 Registered: 2-2007 Posted From: 24.121.215.187
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 18, 2008 - 12:32 am: | |
im in a big jam here in kingsman az the engine i just put in had a severe over heat enough to seize the engine. im here with my family we were on the way to las vegas from nc for vacation. i had the bus towed to the freight liner dealer here but there not sure they can work on it gmc 8v71 1961 model. who can work on it around here and not rip me off? has anyone had this happen what damage would be done? i need to get it fixed asap. were between flagstaff and las vegas thanks!!!!!!!!!!!!!!! |
Syl Szucsko (Syl)
Registered Member Username: Syl
Post Number: 24 Registered: 6-2006 Posted From: 74.32.215.161
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 18, 2008 - 9:42 am: | |
Hi Geo. there is a mechanic in Lake Havasu city. call me at 928 846 2622 |
Post Number: 428 Registered: 8-2006 Posted From: 198.66.72.9
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 18, 2008 - 2:08 pm: | |
A&A Diesel in Needles Ca His name is Andy and has road service he is about 40 miles from you sorry but I am in Texas and do not have his # but he is in the directory he is a great 2 stroke guy also the same freghtliner dealer has 2 good 2 stroke guys in Needles,if you need a complete engine I think Andy has a couple of 8v71's at his shop.Good luck |
Ben B. Wolff (Ben_mc7)
Registered Member Username: Ben_mc7
Post Number: 19 Registered: 4-2007 Posted From: 24.73.7.114
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 18, 2008 - 3:07 pm: | |
I have an 8-71 that I have had on the bulletin board. Make me an offer. 941-725-0636, cell. |
Post Number: 1194 Registered: 10-2003 Posted From: 71.58.110.9
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 18, 2008 - 6:34 pm: | |
From my experience, if severely overheated, the heads most likely will be cracked- have them properly checked for this; usually the crank and bearings aren't hurt, but the block will need to be checked for cracks in liner areas and will probably require new piston and liner kits. The block bores will need checked for warpage and lightly honed or cleaned to remove varnish from cooked oil. It may require precision honing and oversize liners for a proper job as the liner to block fit is critical for heat transfer. Don't just take it to any shop; find one experienced in two cycle Detroits. Remember, your engine is a left hand unit, so a non GMC engine will require extra labor to change over from right hand to left hand rotation. |
larry currier (Larryc)
Post Number: 181 Registered: 2-2007 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 18, 2008 - 11:10 pm: | |
Well.... when they sieze a piston its usually just one! Usually as soon as they cool off, you can get them to start and run home. The piston will knock like a rod knock but you can usually run some miles unless its cracked or has a hole in it. Labor will kill you to repair your engine so get another one. |
JR Lynch (Njt5047)
Post Number: 257 Registered: 7-2006 Posted From: 69.132.233.230
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 27, 2008 - 11:24 pm: | |
Labor to reverse a RH engine will kill you too. That's a major operation. If your engine is trashed, IMHO, the least expensive, and most ASAP repair will be with a good used GM takeout. The hard part is establishing "good" motors from really bad motors. If a dealer begins to dismantle your engine, get your wallet out! A worse case could run to $15K. I wouldn't let anyone perform any repairs, other than a resonable attempt to establish what has failed. Then you can fly mama back home, and form a game plan. If the motor won't bar over, find another motor. Rebuilding and engine when 2500 miles from home is a bad idea. Be ready to stand there and tell the guys how the engine cradle is removed. The new guys just don't know these things. They know how to charge $100 bucks and hour...which I have no problem with as long as they are productive and knowledgeable. Rare. I'll bet the shop would rather you pay them to swap in another motor than to get involved in rebuilding an 8V71. A good takeout could be installed in a day or two. Maybe you'll get lucky and find some minor issue...hope so! May I suggest you have some alarmastats installed in your new engine...they'll save your bank account. Don't forget to fix the cooling system fault! JR |
