john montgomery (Johnjem)
Registered Member Username: Johnjem
Post Number: 38 Registered: 3-2007 Posted From: 66.30.81.16
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 20, 2008 - 9:56 pm: | |
with ether fiberglass or alum,just the 4 large long windows on the side my 4905 do i go over all the stock rivets for the stock windows or do i shave down the rivets? |
Post Number: 268 Registered: 3-2007 Posted From: 71.55.193.220
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 20, 2008 - 10:18 pm: | |
John; I have a 4905 and the metal was so rusty that I had to take it off and put new alumimun from the top row of rivets to below the windows. If your steel is ok then shave or cut off the tops and when you put the new material on put a good adeshive and secure to the old with all the fastners approx the same. I used 090 alum.and predrilled 1/2" up and 1 1/2 between the rivet and sanded primed and installed then sanded primed again and finished the paint. It is quite a job but it was worth it in the long run because I got rid of the steel that was rusted very bad. If any help is needed just let us know. GOMER |
Post Number: 39 Registered: 3-2007 Posted From: 66.30.81.16
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 22, 2008 - 7:13 pm: | |
i talked 2 R&M FIBERGLASS they said to build up area around stock rivets with fiberglass or bondo and sand down smotth to the top of rivet and then apply new fiberglass sheet and rivet thru new fiberglass with out hitting stock rivets!? |
Howard Nichols (Hlnichols50)
Registered Member Username: Hlnichols50
Post Number: 6 Registered: 7-2008 Posted From: 70.46.31.2
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 23, 2008 - 9:54 am: | |
John, We make aluminum covers for the 4905 coaches. If you want to give me a call, I can send you some drawings of our covers that other people have used. Our number is 1-800-468-5287. Our company is IBP Industries, Inc. Apopka, FL Thanks. Howard Nichols |
