c.w Van Hagen (Van)
Registered Member Username: Van
Post Number: 22 Registered: 7-2008 Posted From: 72.193.19.183
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 23, 2008 - 3:52 pm: | |
does any body have pics of an installed reciever hitch on an eagle need to install one on my model 15,could use some direction and advice |
Bill 340 (Bill_340)
Registered Member Username: Bill_340
Post Number: 65 Registered: 7-2006 Posted From: 75.249.35.210
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 24, 2008 - 11:32 am: | |
Bolt across the engine cradle from underside, then center the reciever between the cradle frame, that creates a slight off set hitch allowing you to see the edge of your tow at a glance, tows strait had one for years that way. |
Post Number: 475 Registered: 8-2006 Posted From: 71.30.179.250
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 24, 2008 - 11:59 am: | |
CW, mine has 2x2 square tubing between the engine rails with 5/8 plate welded on top of the tubing hole drilled in the plate bolted to the top with 2- 3/4 bolts where the last holes are in the engine rails and a 5/8 2 inch wide strap tied to the front engine cradle mount with 2x2 piece of angle iron welded to the cradle and a 1/2 inch bolt 3 bolts to remove the hitch.Don't do like I did the first time and line it up with the engine.I have photos but not smart enough to post them (Message edited by luvrbus on July 24, 2008) |
Post Number: 476 Registered: 8-2006 Posted From: 71.30.179.250
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 24, 2008 - 12:01 pm: | |
CW, mine has 2x2 square tubing between the engine rails with 5/8 plate on top bolted to the top of the engine rail with 2 3/4 bolts where the last holes are in the engine rails and a 5/8 2 inch wide strap tied to the front engine mount with a plate and a 1/2 inch bolt 3 bolts to remove the hitch.Don't do like I did the first time and line it up with the engine.I have photos but not smart enough to post them |
c.w Van Hagen (Van)
Post Number: 32 Registered: 7-2008 Posted From: 72.193.19.183
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 25, 2008 - 10:44 am: | |
thanx,we will have to get together when you get back can probably help ya there |
larry currier (Larryc)
Post Number: 190 Registered: 2-2007 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, July 27, 2008 - 11:07 pm: | |
A hitch on an Eagle usually requires a change in the exhaust system. Most end up dumping behind the pass side drivers. |
Robert Ward (Augusta)
Registered Member Username: Augusta
Post Number: 1 Registered: 7-2008 Posted From: 72.202.138.252
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 01, 2008 - 5:52 pm: | |
Don't forget to unhook your electronics. I found out the hard way. $1500 mistake. reward |
