Need ideas for getting windshield sea... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » June 2002 » Need ideas for getting windshield seal installed « Previous Next »
Posted on Sunday, June 16, 2002 - 5:28 pm:
Ok, i give... I put new windshields in my Crown today and got them all in as they should, BUT the rubber gasket "finishes" with a little center-rubber strip that wedges everything together. I can't for the life of me figure out how to get it in sans making a polished stainless tool somewhat like a zipper.... anyone know an easy (or hard) way?
Here's a photo of what it looks like:
http://www.heartmagic.com/zzwindshieldsseal.jpg
Thanks!
Gary
Peter Broadribb (Madbrit) (170.215.33.5)
Posted on Sunday, June 16, 2002 - 5:31 pm:
Gary,
I would ask at your local windshield place if they will rent you the tool or a few bucks to one of the ionstallers will probably get him to run that strip in for you. NAPA may even stock it.
Peter.
Dale Fleener (64.66.217.22)
Posted on Sunday, June 16, 2002 - 5:49 pm:
Seems to me that I saw an article on this subject by Dave Galey in Bus Conversions mag. Can't put my hands on it right now tho. He made a tool to do it.
Dale
Posted on Sunday, June 16, 2002 - 6:05 pm:
Firecall! I Just got it!!
I made a little tool out of stainless spring sheet that I shove in the groove and follow with the rubber... lots of soapy water and it goes in!!
http://www.heartmagic.com/zzGotTheWindshield.JPG
Thanks anyway!!!
Gary
Jim Ashworth (Jimnh) (172.148.37.193)
Posted on Sunday, June 16, 2002 - 8:15 pm:
Lots of tool manufacturers make these tools. Check out your local auto supply store, (not Pep-Boys,etc, but the real ones) or Snap-On. You can put the rubber strip in under 5 minutes per windshield with the right tool.
Jim
Tom Connolly (64.58.193.102)
Posted on Sunday, June 16, 2002 - 9:09 pm:
You can make the tool in 5 minutes for under $3! Easy as 1,2,3.
1- Take a very large cotter pin, like one for a 3/16 hole and 3" long.
2- Enlarge the loop end by spreading the legs open and closing the loop over anything round of the same diameter as the rubber wedge (a 1/4 dowel or drill bit...) will work.
3- screw the legs of the enlarged cotter pin in to a file handle and Walla you own a window tool!
Posted on Sunday, June 16, 2002 - 9:38 pm:
Thanks guys! I ended up getting both windshields in- took about 10 minutes once I got the tool bent right and the "hang" of it. Yippee, no more cracked glass!!
Cheers
Gary
