8v71 oil leaking between head and block Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » August 2008 » 8v71 oil leaking between head and block « Previous Next »
David Lower (Dave_l)
Username: Dave_l
Post Number: 41
Posted From: 69.196.133.195
Posted on Friday, August 08, 2008 - 5:04 pm:
Hello all,
Is it posible for head bolts to come loose to cause oil to leak out between the heads and block, my engine runs and starts good does not run on and has oil pressure and does not over heat? Or would the engine suck oil and not shut off if the head was that loose. My other idea is one of the ruber rings between the head and block is gone. Thanks for all advise Dave L.
Post Number: 1328
Posted From: 76.68.132.186
Posted on Friday, August 08, 2008 - 10:50 pm:
Yes.
Pull the covers and see if the head bolts are loose. Follow proper steps to re-torque to the proper values and see what happens.
Not uncommon to find a loose head in big transit...
