Post Number: 57 Registered: 10-2004 Posted From: 75.69.223.64
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 20, 2008 - 6:10 pm: | |
Hey "Best and Brightest" All this talk about gens has got me thinking. How do you calculate the engine size for a genend? |
Post Number: 510 Registered: 8-2006 Posted From: 74.32.83.140
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 20, 2008 - 7:01 pm: | |
Doug, Kubota has this site for hp and kw http://www.kubotaengine.com/products/bg/d1005_e3bg.html if I have this address right it will be the first click the engine model for ratings.www.wentec.com has a calculator for this (Message edited by luvrbus on August 20, 2008) |
Post Number: 847 Registered: 11-2004 Posted From: 71.180.67.29
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 20, 2008 - 9:11 pm: | |
Approximately 1 HP = .75 KW (less losses) - HTH |
Post Number: 494 Registered: 1-2005 Posted From: 97.104.15.189
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 20, 2008 - 9:49 pm: | |
General rule of thumb for small generators 2 HP of engine for every 1 Kw of generator example 10HP engine for a 5kw generator (Message edited by pete RTS/daytona on August 21, 2008) |
Larry & Lynne Dixon (Larry_d)
Post Number: 162 Registered: 7-2005 Posted From: 71.111.188.44
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 20, 2008 - 10:36 pm: | |
Ok here goes if a genny diesel motor is 1.0 liter how many horsepower? |
Post Number: 511 Registered: 8-2006 Posted From: 74.32.83.140
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 20, 2008 - 11:15 pm: | |
depending on the manufacture but 18 to 35 hp the engine in my New Holland tractor a 1.0 is 33hp at 3100 rpm |
Post Number: 163 Registered: 7-2005 Posted From: 71.111.188.44
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 21, 2008 - 12:56 am: | |
I finally read on in DA BOOK and found this is an ISM diesel, 3 in line, 4 main berring,cast iron block,954 cc, 13 hp @1950 RPM. My goodness what can be learned if you read DA BOOK. larry |
Post Number: 58 Registered: 10-2004 Posted From: 75.69.223.64
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, August 25, 2008 - 8:56 pm: | |
Thanks guys, as usuall cool info |
Post Number: 2085 Registered: 1-2001 Posted From: 75.108.85.14
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 26, 2008 - 12:34 pm: | |
Doug, be careful of basing the alternator size based on the diesel engine manufacturers data. This data is in many cases based on a stripped engine with no muffler, no alternator and maybe no water pump or other accessories. I would feel safe using it for a 5kw alternator and probably with a 6.5kw head. Richard |
Tom Christman (Tchristman)
Post Number: 14 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 05, 2008 - 11:35 am: | |
Make sure you look at the horsepower curve of the engine since many are rated at a much higher rpm than the normal 1800rpm of a heavy duty brushless alternator. And that rating should be for continuous output. So if you have a 12kw, look for a 20-24hp continuous rated engine at 1800rpm. Good Luck, TomC |
