Maxi Briake Conversion Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » October 2008 » Maxi Briake Conversion « Previous Next »
Jim Rink (Fakeguy)
Username: Fakeguy
Post Number: 122
Posted From: 70.61.17.72
Posted on Monday, September 29, 2008 - 5:41 pm:
I still have the original brake system on my '62 4106 (air applies brakes...no air, no brakes and will roll freely). I want to convert to MAXI's....looking for how-to and part resources. All help appreciated.
Thank you in advance
Post Number: 295
Posted From: 71.55.199.152
Posted on Monday, September 29, 2008 - 8:23 pm:
Jim; I had an 06 and had a problem and I like you said I'll just put on maxi's. NOT. They wouldn't fit without $$$$$. so drawing board here I come. Found out the dd3 chambers needed to be rebuilt and that solved ALL my problems. Now there maybe available replacements for them now but then NOT! Maybe someone will be able to assist you further in this matter.
gomer
Jim Rink (Fakeguy)
Username: Fakeguy
Post Number: 123
Posted on Monday, September 29, 2008 - 10:23 pm:
Marvin...not sure what you mean. I do not think I have DD3...Mine are original where air applies brakes not holds them off like maxi's. It takes air to have any brakes at all unlike maxi's that uses air to release brakes...or may I am just confused. Not sure what DD3 brakes are...either way, thank you for the reply
Laryn Christley (Barn_owl)
Username: Barn_owl
Post Number: 514
Posted From: 151.199.126.23
Posted on Tuesday, September 30, 2008 - 12:01 am:
I believe the rear mounting bracket will have to be moved. I don’t think it is all that expensive and absolutely worth every penny. I can try to take photos of mine when I have the wheels off but that might be awhile. If I locate any photos on the web I will post a link.
Username: Barn_owl
Post Number: 515
Posted on Tuesday, September 30, 2008 - 12:17 am:
Special note: This photo is not of my bus, I only wish it was.
GM4106 spring brake conversion:
http://webpages.charter.net/schula/bus9.htm
Taken from:
http://webpages.charter.net/schula/index.htm
Username: Pvcces
Post Number: 1224
Posted From: 65.74.65.209
Posted on Tuesday, September 30, 2008 - 12:19 am:
Jim, there have been quite a few people who thought it was worth going to spring brakes, like you want. Since they were not an option for original equipment, some modifications are needed that increase your liability if a failure in your installation plays any role in an accident.
We were faced with the same choice around 8 years ago, and we considered DD3, but I coudn't stand the price those chambers brought. I inquired about fitting spring brakes on ours and got a shop to modify the brackets that the cans bolt to.
These have to be shortened about 2 inches to accept the spring pots. Since the brake on a wheel end will fail if one of these mounts should break, they have to be very strong. With the shorter brackets, there should be about 1/2" of room between the pot and the bulkhead when installed.
Do not cut a hole in the bulkhead to make room for these cans. I have seen a bus that had this done and the bay floor wrinkled and cracked from the loss of support.
Be sure that the air for the parking brake valve comes from the brake side of the system, not the auxiliary. Your air gauge should be on the auxiliary side.
We have never regretted going to spring brakes, and I could not accept the stock equipment with Johnson bar and ICC valve. If you should be going down a long mountain grade at a pretty good clip and blow the diaphragm on either rear pot, you would lose both the service brakes and the ICC circuit. The Johnson bar by itself would be inadequate, in my opinion.
The stock pot has one hose, the spring brake has two hoses and the DD3 has three hoses. That should end any confusion about which equipment you have.
For what it's worth and YMMV.
Suncatcher
Ketchikan, Alaska
Post Number: 479
Posted From: 208.100.193.170
Votes: 2 (Vote!)
Posted on Tuesday, September 30, 2008 - 7:33 am:
"and I could not accept the stock equipment with Johnson bar and ICC valve. If you should be going down a long mountain grade at a pretty good clip and blow the diaphragm on either rear pot, you would lose both the service brakes and the ICC circuit. The Johnson bar by itself would be inadequate, in my opinion."
Well I guess the size of the hill is the key here.
I have sucessfully slowed (at a reasonable rate as most traffic does) with ONLY the Johnson bar as an experiment on the interstate.
It will bring the bus to a normal stop should the ICC system fail at the same time as the regular breaks.Might not on the Grapevine tho.
I prefer the stock system as with a failure the coach can still be owner moved , not require the wait for the hook.
I have read of folks that lost the air compressor , ran the noisemaker and a small air compressor and were able to run home (a few days travel) to repair.
Different strokes,
FF
Username: Kyle4501
Post Number: 450
Posted From: 65.23.106.193
Posted on Tuesday, September 30, 2008 - 8:02 am:
When installing the spring brakes, make sure you have room to install the "cage" bolt. (It retracts the spring mechanically, no air needed.)
Otherwise, towing it may prove interesting. :-)
Username: Barn_owl
Post Number: 516
Posted on Tuesday, September 30, 2008 - 9:51 am:
At normal ride height there is very little to no room to access the cage bolt on a 4106 that has been modified to spring brakes. The reason one needs access to the cage bolt is that it allows you to back off the spring so you can move the bus or work on the brake chamber (There are other ways around that, but it requires a lot more work, time, etc.) Depending on what type of leveling system you have, you can raise the bus a few inches to obtain access to the cage bolt. Without a leveling system, disconnect the leveling valve rod and manually adjust it to accomplish the same result, you only need a few inches. For those reading this that might not be familiar with air ride buses, it is absolutely life or death critical, that you properly block your bus up while you are under it. Also, do not work on the brake can unless you have educated yourself on the dos and don’ts. That spring can make them as dangerous as a cocked pistol if not handled correctly; it can maim and kill also.
Post Number: 296
Posted on Tuesday, September 30, 2008 - 6:29 pm:
Barn Owl; Is that a new 4106 or what? I ain't seen one that clean since I went on a tour of a conversion company in Indiana. Wow that is cool and I do like the set up. When I had mine they didn't make anything that would work SAFELY and I would not take a chance.
Gomer
Username: Bigrigger
Post Number: 103
Posted From: 24.179.147.233
Posted on Tuesday, September 30, 2008 - 9:54 pm:
If your going to upgrade, I would suggest going all the way to modern maxi brakes and not DD3's. I can get a replacement maxi can for my truck for $50-75 and just the two diaphrams for these DD3's cost me $183!
Tom Christman (Tchristman)
Username: Tchristman
Post Number: 24
Posted From: 66.218.33.156
Posted on Wednesday, October 01, 2008 - 11:16 am:
All trucks and buses now have Maxi brakes-where air pressure is used to release the brakes and no air will apply them. If you haven't experimented to see how well they work, do it in a parking lot. Get up to 20mph and apply the brakes. Should be a sharp braking effort.
To install maxis on a non maxi bus, you just need an air supply to the yellow pull valve, air line back to the rear axle, a T to the two cans. No air relays needed-simple install-but very effective. Good Luck, TomC
Jim & Linda Callaghan (Jimc)
Username: Jimc
Post Number: 55
Posted From: 66.175.206.159
Posted on Wednesday, October 01, 2008 - 4:51 pm:
Marvin,
I think that picture came from Al Schultz's (Southern Wis) bus, he did the work himself, and the rest of it is that clean also, check out the link by the pictures.
Jim
Jim Rink (Fakeguy)
Username: Fakeguy
Post Number: 124
Posted on Wednesday, October 01, 2008 - 8:49 pm:
WOW...thanks for all the replies. I am reconsidering my decision based on all the input, but now with lots of info
Thank you to all
Username: Barn_owl
Post Number: 517
Posted on Friday, October 03, 2008 - 12:17 am:
Gomer,
I can honestly say I have never seen a GM that clean. I truly don't know how people do it.
Laryn
Username: Barn_owl
Post Number: 518
Posted on Friday, October 03, 2008 - 12:30 am:
I need to mention that just because you convert to spring brakes doesn’t mean you need to remove the manual parking brake although most people do. The PO of my bus left it in and it still works. Here in the mountains I take my bus places most people wouldn’t, and I wouldn’t want to depend totally on just a manual parking brake. That might just be my own paranoia but so be it.
Jim Rink (Fakeguy)
Username: Fakeguy
Post Number: 125
Posted From: 192.88.212.44
Posted on Friday, October 03, 2008 - 12:51 pm:
Barn Owl: what's a PO?
Username: George_mc6
Post Number: 572
Posted From: 207.231.75.253
Posted on Friday, October 03, 2008 - 1:06 pm:
Previous Owner
Post Number: 298
Posted From: 71.55.193.233
Posted on Friday, October 03, 2008 - 5:49 pm:
I checked out the pictures of the coach and that is awsome. Was he totalled retired? I barely have time to work on mine let alone wash it LOL
If you haven't seen the pics GO DO IT NOW!!!! You will be ashamed of yourself after that.
Gomer
Username: Gusc
Post Number: 737
Posted From: 208.54.200.110
Posted on Friday, October 03, 2008 - 6:43 pm:
Jim,
As I remember the brake pots come in two sizes and the smaller ones have to be used on a 4104 so I assume the 06 needss the same size.
Barn Owl,
My guess is that the spring maxi wheel brakes are about four times as effective as the original hand one brake drum on the drive shaft. There is almost no way both spring brakes can fail at the same time unless they are grossly out of adjustment. I have a few antique trucks with those drive shaft hand brakes and they are pretty useless.
Username: Pvcces
Post Number: 1228
Posted on Friday, October 03, 2008 - 10:24 pm:
Gus, we have 30-30 pots installed on our coach. There are smaller ones made.
It's always possible for a spring to break, so parking on a steep grade is not a good idea.
I also noticed an Australian government spec to test spring brakes. They were required to stop a full load on a 20% grade and set the parking brake.
If it held, the brakes passed the test. If one spring was broken, then the parking brake would not hold.
If the brakes were way out of adjustment, they wouldn't hold, either.
Years ago, when we bought a pump truck, we had to replace pots because the springs were broken. The replacement pots had vinyl coatings on the springs, probably to slow down the rust.
I know of at least one case of someone loading a dumptruck with a backhoe and the truck took off down the hill when it was heavy enough.
For what it's worth.
Suncatcher
Ketchikan, Alaska
Patrick levenson (Zubzub)
Username: Zubzub
Post Number: 27
Posted From: 64.229.55.234
Posted on Sunday, October 05, 2008 - 12:37 pm:
My handbrake stops the bus from 50 mph quite agressively. It's in good shape and adjusted well. I like the belts and suspenders lookm so when I have installed maxis I will keep the drive shaft brake as well, can't be too safe.
Username: Chessie4905
Post Number: 1208
Posted From: 71.58.110.9
Posted on Sunday, October 05, 2008 - 6:59 pm:
The shorter pots will not fit in the space on 4106 or later models. They have about two inches less room than the shortest available pot requires.DD3's would be the best bet if you don't mind getting all the other components that go with that system from a donor vehicle. Could be expensive. Re fabricating the brake mounts is one possibility if done properly. The addition of recesses in the baggage compartment is quite feasible and will work well if done by someone that can perform the modification without causing weakness to the compartment. Remember to allow for clearance of brake cans when suspension is at full height, such as going over a big bump. BTW, that pic looks like the maxi's won't clear the bulkhead. Might be the angle OR maybe not.
