Fanbelt idler pully Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » October 2008 » Fanbelt idler pully « Previous Next »
Robert C. Meyers (Bob_meyers)
Username: Bob_meyers
Post Number: 8
Posted From: 67.49.33.40
Posted on Thursday, October 02, 2008 - 8:58 pm:
I need info on an idler pully for a 1990 Prevost LeMirage XL. The motor is an 8v92ta ddec. Currently there is no pully. This is the one that drives the dash air a/c unit. The belt keeps jumping off the pully. Thanks, Bob
Username: George_mc6
Post Number: 570
Posted From: 207.231.75.253
Posted on Friday, October 03, 2008 - 1:31 am:
Bob,
From previous experience with the same problem, an idler pulley won't clear it up. I would make a large wager that the compressor is not lined up square with the engine pulley. It may take a four foot straight edge to find it, but the compressor will either be in front or back of the engine pulley, or the comp is not parallel to the cam.
George
Username: Luvrbus
Post Number: 548
Posted From: 74.33.57.23
Posted on Friday, October 03, 2008 - 10:04 am:
Bob, here is the prevost # for the idler and arm if it will help 51-0338 for the pulley and 05-1663 for the arm and it had a air cylinder for tension good luck
Post Number: 9
Posted on Saturday, October 04, 2008 - 11:23 pm:
Thanks for the information. I'll check the alignment of the pulleys and use the parts numbers if necessary. Bob
Post Number: 10
Posted on Thursday, October 23, 2008 - 6:47 pm:
The compressor was out of alignment by 1/2". Thanks for your help. Bob
Post Number: 598
Posted From: 76.91.197.153
Posted on Thursday, October 23, 2008 - 9:00 pm:
Thank you for the post!
George
