Post Number: 174 Registered: 12-2000 Posted From: 71.99.25.84
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 18, 2008 - 6:28 pm: | |
When I open the thread "Homemade battery charger - Quartzite" it comes up with very wide margins, so that you have to scroll sideways. No other thread does that that I can see. Does the same thing in Firefox or IE. Just curious what might be happening here. Len |
Post Number: 849 Registered: 12-2000 Posted From: 70.0.237.160
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 18, 2008 - 7:46 pm: | |
Same thing happeed with me using IE. Only thing different that I noticed on that thread was the photos that Doyle posted. I have no idea if that is what is causing the difference. Jack |
Dale Houston (Songman)
Registered Member Username: Songman
Post Number: 65 Registered: 8-2006 Posted From: 69.104.172.22
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 18, 2008 - 10:09 pm: | |
Len and Jack, I would guess that it is because the photos that are posted in the thread are larger than you have your screen resolution set. In my case, the resolution of my screen is larger so the photos do not stretch the margins. The photos are 640x480. If you have your screen resolution set at 800x600, the pictures plus the side bar area probably add up to more than the 800 pixel width. It will happen regardless of browser. If you want to test the theory, change your screen resolution to 1024x768 and look at the thread again. Dale (Message edited by Songman on October 18, 2008) |
Post Number: 1117 Registered: 7-1997 Posted From: 24.239.15.211
Rating: Votes: 1 (Vote!) | Posted on Sunday, October 19, 2008 - 3:01 pm: | |
Hi Len, Doyle placed his pictures side by side, so I've stacked them, instead. Your browser should be ok now. Ian www.busnut.com |
Registered Member Username: Texasborderdude
Post Number: 145 Registered: 3-2007 Posted From: 75.211.82.114
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 19, 2008 - 3:01 pm: | |
I think I should have inserted a <br> (html code for break or carriage return between the code for the photos so it wouldn't try to resolve wider than the page width on your browser. I'm gonna try to edit it and see if that's it... dg |
