Which Steel will do? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » July 2002 » Which Steel will do? « Previous Next »
Ron R. (64.12.96.235)
Posted on Monday, July 15, 2002 - 8:41 pm:
I am having steel pins made for the upper A arms for my o-1 eagle. These pin's slip inside rubber bushings. The steel fabricator ask me if they needed to be real hard steel. Any comments from the "Great Ones" would be appreciated.
Thanks,
Ron
Jayjay (65.142.15.14)
Posted on Monday, July 15, 2002 - 9:13 pm:
Ron, even though they are inside rubber bushings, they still take a terible beating, and if the rubber fails, your life may depend on the extra bit of hardness in a well made 4130 or 4140 pin. Care must be exercised to not use a grade that is too hard, or "brittle". Personally I would opt for the 4140, but without any sort of heat-treating or surface hardening. Be sure they are "smooth", with no nicks or gouges in them, since these "stress-risers" are particularly bad on a piece that has almost all of it's load in "shear". Cheers...JJ
Ross Carlisle (Ross) (216.107.195.188)
Posted on Monday, July 15, 2002 - 10:01 pm:
I would find out what alloy the originals were made from and use the same. Suspension parts are not exactly the best parts to "re-engineer".
Ross
Bradd B. Smith (Bbsrtbusproject) (208.26.165.28)
Posted on Tuesday, July 16, 2002 - 12:34 am:
Ross is right. Most of the pins I have encountered in my 20 year machinist history, in this application, have been case hardened mild steel. Wear surface is good and not brittle because of the ms core. However, I would do my homework and make sure. Unless your fabricator is very well equiped, case hardening will be beyond their capacity. 4140 is an excellent, high carbon steel, but in a non-heat treated state offers very little wear improvement. It's shear strength is good. Again, I would find out what the original pin's were made from, and try and find a Cat or other truck crossover application.
chris (66.76.182.147)
Posted on Tuesday, July 16, 2002 - 8:02 pm:
i would suggest using EDT150 which is basically 4i40 material which has been quinched & heat treated. It has excellent wear properties and is not brittle most machine shops keep this.
e
